Hi,
I have built a Threadripper home server with the following spec:
OS: Proxmox 5.3
CPU: 1920X
RAM: 64GB ECC
MB: Asrock X399 Professional Gaming @ BIOS 3.30
GPU: Inno3D 1050Ti
HBA: SAS9305-16i
SVM, ACS, PCIe ARI, IOMMU, SR-IOV Enabled in BIOS.
GPU Passthrough works very well using vBIOS patcher, however I met a glitch when passing USB Controller. Both USB controllers are isolated in their IOMMU group.
IOMMU group 22: [1022:145c] 08:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) USB 3.0 Host Controller
IOMMU group 40: [1022:145c] 42:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) USB 3.0 Host Controller
I passed one of them to the VM, but if there is anything plugged in the USB port when VM start, the whole system will hang. It works if I unplug the USB device and replug it after VM start. VM reboot is not affected.
By default USB Controllers are using xhci_hcd driver, it seems like xhci_hcd has trouble when passing control to vfio_pci with device attached.
To resolve this issue I had to use a script:
echo 0000:42:00.3 > /sys/bus/pci/devices/0000:42:00.3/driver/unbind
echo 0000:42:00.3 > /sys/bus/pci/drivers/vfio-pci/bind
echo 0x1022 0x145c > /sys/bus/pci/drivers/vfio-pci/new_id
Has anyone met this issue ? Since no one mentioned this problem when passing USB with Threadripper.
