Threadripper Unraid build HELP
Hello everyone, long time LVL1 fan but first time posting to the forums. I enjoy playing games and streaming on twitch. I have a 6700k maxiumus viii gtx 980 gaming machine to which i use for gaming and streaming. I also have a second pc that i use as a server. That machine is old, has an i3 chip on it and nothing special about it. I run unraid on it and setup nextcloud. I would like to run some VMs but the hardware cannot support it. So the plan is do a major upgrade and move towards threadripper. The new build will continue to run Unraid as the underlining OS.
The current plan is a 1950x 32g of 3200 ram. Havent picked out a board yet. I am going to run Unraid, nextcloud file sever, plex server, I would like to run a windows VM and do hardware pass through to do use as a streaming PC.
I have 3 questions that would really help me out if anyone could provide me some incite.
  1. Could I run a vm with hardware pass through a NIC to run PFSENSE?
  2. Updating two machines a gaming rig and then a server is expensive, performance wise is it worth setting up another VM on the server using pass through of a graphics card to run as my gaming machine?
  3. Budget wise im at the $600 range for cpu which would be the 1950x or 2920x I like the idea of more cores with the 1950x but as i stated above for application which should i choose?
  1. Yes, absolutely. In fact NICs were one of, if not the hardware piece that PCI passthrough was invented for.
  2. It is possible to do so, but that is such a loaded question on if it is it worth it.
  3. The 2920x is not that much faster per core, and you are doing lots of things at once on the server, so I would generally recommend the 1920x. If the 2920x is a lot cheaper where you live, then it might be worth taking another look at, but if you do decide to have a gaming VM also on this system then go for the 1950x(or better).
Thanks I’m excited to setup pfsense with a vpn and have my existing routers turned into just dummy access points. Also I’m in the Ohio area so I have access to micro center and have been keeping a close eye on cpu prices as well as I’ve considered just getting an open box on the board. The TR4 boards are not cheap.
