Threadripper system as a business server
Hello all,
I’m looking to build a server for our small office.
It will be used for some small workstation VMs plus, file server VM and Windows Server VM for our ERP system.
I would like something that we can grow into.
I’ve been looking at an duel xeon build from Dell. Something in the 5-10k range. Then I got thinking about threadripper. I could build a nice system that would be plenty powerful enough.
What would be the negatives of going the non traditional server route?
That you very quickly are out spec’ed if your business is growing.
I would suggest you look into used Xeons or Opterons if you really feel Team Red.
If you run a bunch of VMs and wanna add more VMs you need cores. Options / Xeons are the way to go.
If you run a File Server you need hard drives, a lot of them if growing so that is also important.
If you guys deploy more services you maybe wanna give the VM they’re running in more cores.
So if you wanna do enterprise, buy enterprise gear.
BUT if you wanna have some fun and do some weird stuff, by all means do so BUT when it’s for a business handle it professionally.
Epyc custom build is an option. Only downside of tr is less lanes,no ipmi,less mem capacity and bandwidth. I see no negative to going tr if you done need those features
barebones epyc servers are a thing, and very good hardware. supermicro and gigabyte have some seriously swanky stuff. and its just add cpu, ram and storage.
Thanks all.
Enterprise hardware is going to be the way to go.
I’ll build an epyc system. I’ll check out supermicro and gigabyte. This will be more fun then ordering a dell and plugging it in.
that said I might have spied a TR board with ipmi.
I also spied am AM4 board with ipmi :smiley:
hmmmm, very interesting!
Seems like maybe I should wait to build something. Lots of new stuff coming down the pipes.
It is going to be fun watching AMD the next little while. It is so nice to see the competition.
The difference between say a self-built threadripper and a Dell or other “proper” server will also be things like hot-swap power supplies, hot swap disk bays, hot swap fans, redundant fans, redundant power supplies, iDRAC (or other) lights out management, etc.
Going self built, you’d also be giving up guaranteed replacement parts inside of an SLA.
If it is a server that you will need to support, possibly from remote - whatever you buy i would suggest that you get a board with lights out management and ideally redundant PSUs and hot-swap drive bays. Whether that is Xeon, EPYC, etc. Because murphy’s law says that the disk failure or OS crash and reinstall requirement will happen when you’re on holiday or on the weekend or whatever. With lights out management you can fix that stuff from elsewhere. So if you DO get a board with those features, make sure to set them up!
Also, the box with lights out management can maybe even email you of either impending or actual hardware failure BEFORE people notice it. So you can do stuff like get an RMA disk from DELL or whoever shipped ASAP, get the secretary to replace the disk with the orange light on it and monitor the raid rebuild or whatever from home.
Being workstation focused, i don’t think you’ll likely get a Threadripper board with lights-out management, but i could be wrong.
Self built boxes on the cheap can be fun to see what you can get for less money. Just be aware that in the real world, businesses tend to scream when things are broken, and also tend to scream when it takes time to repair. Going for a proper server grade box with an SLA on replacement parts and some level of monitoring and hardware redundancy will save your arse (and your sanity) in those circumstances. The extra few dollars will likely pay itself off inside the life of the machine via reduced downtime.
Also - if you’re waiting on parts from DELL (who are generally pretty good with RMAs) - you can blame DELL. If you’re unable to source parts on a self built machine, it is YOUR FAULT and YOUR PROBLEM.
One way of justifying the (usually not massive) additional cost, is to figure out how many people won’t be able to work while the machine is broken, get a rough idea of the average hourly rate and mutiply out the numbers. In even a 5-10 employee company, being down for a day (instead of an hour or whatever) costs you a shit-load of money - it doesn’t take long for the proper server grade gear to pay itself off.
e.g., 10 staff @ $40/hr x 9 hours = $3600 in wages paid to people who can’t do their job… if you’re down for a single business day. Never mind things like lost business opportunities, production impact, etc. Definitely put numbers like this forward to the guys paying the bills. They may consider it worth paying the extra to mitigate the risk. Or they may not - but at least if they are informed, then your arse is covered - they made the call to trade off cost vs. reliability/support. “How much will it cost if this is broken for a day” should definitely be a discussion you have with the business.
Tempting as it is to claim that “oh i can support it myself!” - that’s a dangerous path. Under-promise and over-deliver, rather than putting yourself in the reverse situation when things go unexpectedly pear shaped.
2c. I’d personally NEVER go self built for a server i’m putting in to a business environment that I am expected to support. I had to deal with non-server grade hardware in that environment earlier in my career. It’s not worth the cost saving in my opinion.
Also - in most small business environments - server CPU performance is pretty irrelevant. They’re all fast enough for general file/print/email/etc. So performance benchmarks are often irrelevant. Reliability, ease of support and replacement hardware SLAs are what will make or break your choice. Unless you KNOW that your business workload is CPU bound - don’t go chasing CPU bang for buck performance at the cost of support and reliability features.
Small office (how many staff?) file/print/ERP, IMHO even an i5 or i7 (with enough RAM and IO throughput) will probably run that workload just fine. just because it’s a “server” doesn’t mean you need a 10+ core xeon or whatever. Disk IO throughput and maybe RAM is likely to be more important.
Oh just saw this…
Tread carefully there.
Shiny new things don’t end up in servers very rapidly, for good reason.
Hardware bugs, firmware bugs, driver bugs, OS compatibility bugs, etc. are all things on new hardware.
Right now is probably the best time to be buying WHAT IS CURRENTLY OUT (be it Ryzen v1, Epyc v1, Skylake Xeon, etc.).
All (well, hopefully at least the showstoppers) the bugs have been shaken out, and so long as you’re buying from a vendor as a complete system (e.g., Dell, HP, whatever) you will get your guaranteed 3 years of support or what have you. Even on a self built your components should still have the same/full warranty.
For a workstation (but hell, even then, if downtime is a concern… don’t go there) brand new platforms/chipsets/etc. are all well and good.
Servers? Not so much. Like I said - CPU performance is mostly irrelevant, so this generation or even previous is likely plenty performance wise for SOHO applications.
Of course there are niche use cases where you need as many cores or as much ram or whatever as possible, but typically that isn’t in the small business box market. So unless you know you need the higher performance, don’t go there.
Your goal with server hardware should be to minimise potential head-aches. You want the install process to be dumb as dirt (ideally built in support for the raid controller, etc. in Windows, or ESXi, or whatever OS you plan to use). You don’t want to be waiting a few months for firmware updates to improve stability, etc. You don’t want to be fucking about with boot drivers or special processes at 2am when the thing flaked out and you need to rebuild it before start of business or whatever.
Chasing the new shiny for performance reasons is usually a mistake in this space. The only reason you’d want to do that is for performance per watt or performance per rack reasons, and for small office gear that just isn’t normally a real concern.
2c. and good luck!
