I’m wondering if pairing a TRX40 AORUS MASTER with 4 sets of F4-3600C16D-32GTZNC would work, vs 2 sets of F4-3600C16Q-64GTZNC that are listed as compatible but not available.
Probably but not at 3.6 ghz. I doubt you’d get two x4 sets to work at 3.6ghz either, since that rating is for a single kit.
Start at 2666mhz and work your way up.
Ah okay. Looking at the gskill website I suppose I should count my self lucky if I get 3.2GHz since that is the fastest 16GBx8 kits they sell(for threadripper)
i dont think he’d have any issues running that speed. i have 4 sticks of team t-force xtreme running 3600 cl18 on the xmp settings on my threadripper pc with 0 issues.
now 8 sticks at 3600 might be a different story
Oh, that sounds promising. Is that Samsung B-die?
The F4-3600C16Q-32GTZN (8GBx4 kit @3600MHz) is B-die but the F4-3600C16D-32GTZNC I believe is Hynix C-die.
I was under the impression that Hynix C-die was really good with ryzen, I wish I remembered the source for this though it would be useful now.
Is it likely I would be better off getting 4 sets of 3.2GHz 14-14-14-34 as it is B-die and 8.8ns vs 8.9ns (so perhaps the same, but rounding?)
It’s almost 50% more expensive for samsung B-die than Hynix C-die. It’s not an issue of price if it’s going go get my infinity fabric to run faster with quad channel.
i believe its supposed to be, but there were issues with some kits not being b-die and i cant run the windows memory check software. but i did get the following info
Summary
sudo dmidecode --type memory
Getting SMBIOS data from sysfs.
SMBIOS 3.2.0 present.
Handle 0x0009, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 512 GB
Error Information Handle: 0x0008
Number Of Devices: 8
Handle 0x0011, DMI type 17, 84 bytes
Memory Device
Array Handle: 0x0009
Error Information Handle: 0x0010
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: Unknown
Set: None
Locator: DIMM 0
Bank Locator: P0 CHANNEL A
Type: Unknown
Type Detail: Unknown
Speed: Unknown
Manufacturer: Unknown
Serial Number: Unknown
Asset Tag: Not Specified
Part Number: Unknown
Rank: Unknown
Configured Memory Speed: Unknown
Minimum Voltage: Unknown
Maximum Voltage: Unknown
Configured Voltage: Unknown
Memory Technology: Unknown
Memory Operating Mode Capability: Unknown
Firmware Version: Unknown
Module Manufacturer ID: Unknown
Module Product ID: Unknown
Memory Subsystem Controller Manufacturer ID: Unknown
Memory Subsystem Controller Product ID: Unknown
Non-Volatile Size: None
Volatile Size: None
Cache Size: None
Logical Size: None
Handle 0x0013, DMI type 17, 84 bytes
Memory Device
Error Information Handle: 0x0012
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Type: DDR4
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 3600 MT/s
Serial Number: 01048107
Part Number: TEAMGROUP-UD4-3600
Rank: 1
Configured Memory Speed: 3600 MT/s
Minimum Voltage: 1.2 V
Maximum Voltage: 1.2 V
Configured Voltage: 1.2 V
Memory Technology: DRAM
Memory Operating Mode Capability: Volatile memory
Module Manufacturer ID: Bank 5, Hex 0xEF
Volatile Size: 8 GB
Cache Size: None
Logical Size: None
Handle 0x0016, DMI type 17, 84 bytes
Memory Device
Error Information Handle: 0x0015
Data Width: Unknown
Set: None
Locator: DIMM 0
Bank Locator: P0 CHANNEL B
Type: Unknown
Speed: Unknown
Rank: Unknown
Volatile Size: None
Cache Size: None
Logical Size: None
Handle 0x0018, DMI type 17, 84 bytes
Memory Device
Error Information Handle: 0x0017
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Type: DDR4
Speed: 3600 MT/s
Serial Number: 01048111
Rank: 1
Volatile Size: 8 GB
Cache Size: None
Logical Size: None
Handle 0x001B, DMI type 17, 84 bytes
Memory Device
Error Information Handle: 0x001A
Data Width: Unknown
Set: None
Locator: DIMM 0
Bank Locator: P0 CHANNEL C
Type: Unknown
Speed: Unknown
Rank: Unknown
Volatile Size: None
Cache Size: None
Logical Size: None
Handle 0x001D, DMI type 17, 84 bytes
Memory Device
Error Information Handle: 0x001C
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Type: DDR4
Speed: 3600 MT/s
Serial Number: 01048101
Rank: 1
Volatile Size: 8 GB
Cache Size: None
Logical Size: None
Handle 0x0020, DMI type 17, 84 bytes
Memory Device
Error Information Handle: 0x001F
Data Width: Unknown
Set: None
Locator: DIMM 0
Bank Locator: P0 CHANNEL D
Type: Unknown
Speed: Unknown
Rank: Unknown
Volatile Size: None
Cache Size: None
Logical Size: None
Handle 0x0022, DMI type 17, 84 bytes
Memory Device
Error Information Handle: 0x0021
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM 1
Type: DDR4
Speed: 3600 MT/s
Serial Number: 0104810A
Rank: 1
Volatile Size: 8 GB
Cache Size: None
Logical Size: None
I have 2 sets of F4-3600C16Q-64GVKC running at 3600 with the XMP settings on my AORUS XTREME. I had to get up to at least F3 BIOS to get the compatibility.
Works like a charm, thank you!
