My current setup:
CPU: AMD Threadripper 3970X 3.7 GHz 32-Core Processor (Purchased For $1899.99)
Motherboard: Gigabyte TRX40 AORUS XTREME XL ATX sTRX4 Motherboard (Purchased For $849.99)
Memory: Corsair Dominator Platinum RGB 64 GB (4 x 16 GB) DDR4-3600 Memory ($669.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 120 GB 2.5" Solid State Drive
Storage: Samsung 850 EVO-Series 250 GB 2.5" Solid State Drive
Storage: Samsung 860 Pro 1 TB 2.5" Solid State Drive ($299.99 @ Newegg)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive ($219.99 @ Newegg)
Storage: Western Digital Caviar Blue 500 GB 3.5" 7200RPM Internal Hard Drive
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive ($45.99 @ Newegg)
Storage: Seagate 1 TB 3.5" 7200RPM Hybrid Internal Hard Drive
Storage: Seagate 2 TB 3.5" 7200RPM Hybrid Internal Hard Drive
Storage: Seagate BarraCuda Pro 12 TB 3.5" 7200RPM Internal Hard Drive ($493.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 1080 Ti 11 GB AORUS Xtreme Edition 11G Video Card
Case: Cooler Master HAF Stacker 935 ATX Full Tower Case
Power Supply: EVGA SuperNOVA G2 1300 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 10 Pro OEM 64-bit ($149.99 @ Newegg)
Monitor: Dell AW3418DW 34.1" 3440x1440 120 Hz Monitor
Keyboard: Logitech G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech G502 Proteus Spectrum Wired Optical Mouse
Headphones: Logitech G933 Artemis Spectrum 7.1 Channel Headset
Custom: Corsair Hydro X Custom Cooling Loop (Purchased For $689.99)
During the autumn part of 2020 I decided its was time to swap out my current pc case for one that allowed for better space and cable managment. Ended up with 2 case options caselabs tx10 or thermaltake wp200. You can guess which one I got cause its the only one I could find available new and and an extra P200 to go with it. I’d still buy the caselabs tx10 if someone sold them new or used.
Then ran into a delema. My current corsair hydro x custom loop is not sufficient enough for my pc as I have a mid-high idle 37-44 C. Currently I can’t really complain about the corsair stuff it does the job well. i want something a bit beefer and down the rabbit hole go again.
My question is what is better for my cpu 480mm vs 560 rads? I plan one using EKWB rads and pump/res combo along with the optimus absolute trx40 cpu waterblock. Next problem is which fans to use as I like corsairs rgb fans these product which led me to buy their custom cooling kit. I want to keep the same rgb contollers and other items. EKWB pump/res combo units have their own rgb as well as their vadar fans with rgb. I like the corsair rgb aesthetic but is it better to go with EKWB’s fans for rad cooling?
