Any one see anything that might go awry in this build im basing it on the $1300 build that was uploaded on the show. One thing i'm not too sure of is the weather the Havik could fit into the case, if youve got a havik in a ghost please comment.
Intel Core i5-3570K 3.4GHz Quad-Core Processor
NZXT Havik 140
ASRock Z77 Extreme4 ATX LGA1155 Motherboard
G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory
OCZ Agility 3 120GB 2.5" Solid State Disk
msi gtx 680 or evga 680
Bitfenix Ghost
OCZ Fatal1ty 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply
Cheers
Everything looks good to me but dont get a ocz agility 3 they have terrible reliablility over the long term.
Maybe go for a samsung 830 series or a vertex 4 because they are better drives.
also get the msi 680 because the triple over volting helps with overclocking that thing like a mofo
hope it helped !
Pretty much everything waffle time said. If you want to spring a little extra get the 840, Although the 830 is still one of the best drives out. Also, maybe switch out the Extreme4 with a Gigabyte GA-Z77X-UD3H. The extreme4 isn't a bad board ( I have one) but it has D PACK mosfets which really limit how high you can overclock with it. The mosfet in the UD3H are a lot better
