Thoughts on this case?
Not too many reviews or opinions on this case (Xigmatek Gigas). I am looking for a sub-$100 microatx case that is as small as possible. Thanks
http://www.newegg.com/Product/Product.aspx?Item=N82E16811815016
I prefer Lian Li for those tiny cases.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112316&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Computer+Cases-_-N82E16811112316&gclid=CLKV3v2_z7YCFQypnQodcVAAzw
Can you be a bit more specific?  What components does the case need to have? You can go really small, if you dont need an optical drive or extra GPU.
I like the Bitfenix Prodigy, and it comes highly recommended.
However Cooler master has some cheap ones as-well.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119261
The Prodigy is mITX, not mATX. Personally, I would go with a Silverstone TJ08E - probably the best mATX case out there, for the money.
