Thoughts on power limiting GPU's - issues/benefits
I’m fairly certain I know the answer to my situation, but was wondering what the community had for thoughts on this.
I recently had a long-planned and saved for homelab upgrade go in-place just as power rates climbed near 50% in my area. The previous server was a 1U Supermicro running ESX and would average 112w with all services running. The new server is an R740xd with two V100 32GB GPU’s, 12 DIMM’s and 16 SAS SSD’s all sitting idle at 295w, which goes up quite a bit under load obviously.
I had set the GPU’s with nvidia-smi to 150w knowing that would slow things, but I assumed the overall tradeoff would be lower power use. Qwen 3.8 exposed this slowdown in ways Gemma 4 or Qwen 3.6 did not. So I began trying to optimize so as to avoid the wrath of my family wondering why things were taking so long. Last weekend I opted to return the GPU’s to their default wattage of 250, and holy cow did that make a difference. Speed now feels more ‘normal’ to my home users, and to me tasks are completed in a lot less time. I believe in total the system uses less power over time than with the restrictions.
So that’s my ponder, and I know this has so many nuanced details in everyone situation that there is no definitive yes or no answer. But what have others found in situations where you’re trying to manage power consumption while trying to maintain reasonable performance?
Currently i’m limiting the 6230’s slightly under power at 105w at the top, and the workloads it’s running don’t seem too bothered by that. The system tops out now at around 650w under an AI workload, as long as I don’t spill over into CPU/RAM. Not at all a power hungry monster, but I’m cheap.
ty for taking the time to read :wink:
Applying harsh limits at the top end rarely makes a lot of sense. Turbo boost has been enhanced to raise the ceiling with every generation for a reason. What you really want to do is drop the idle power as much as possible.
When you limit power you’re still using the same voltages for the same frequencies so efficiency changes a bit because you spend less time at the highest points but to more significantly improve efficiency you need to undervolt. This is a form of overclocking so it’s necessary to use trial and error to find the limits of stability for your silicon but that’s where real efficiency gains can be realized without performance suffering.
yes. power limit them. the extra 15% speed usually isn’t worth dealing with the heat, power, noise, etc.
My stuff is usually -PL’d to about 60-80% rated power.
I curve tuned my rtx 4090 and set a power limit of 80%.
Did this in a attempt to reduce some horrible coil whine.
Which it did, it hardly noticeably now.
As a bonus the gpu’s power usage went down 100W on 100% utilization.
I only noticed a slight drop in frame rate of about 5fps, while the card is driving well over 120fps
nope.
power consumption scales exponentially with clock speed.
knock off 10% of the clock speed and save like 30% of the power.
or alternatively: knock off 30% of the power and get 90% of the performance
rough numbers, but you get the idea.
Technically for frequency in isolation power scales linearly while voltage scales quadratically. In practice it’s neither because modern silicon uses dynamic voltage and frequency scaling where both vary in unison. Limiting power tends to reduce both frequency and voltage and similarly when limiting frequency it’s usually the corresponding reduction in voltage that’s responsible for most of the power savings.
That’s why offsetting voltage vs frequency (undervolting) allows efficiency gains without performance loss because you’re trading stability margins for efficiency not frequency.
You should undervolt/underclock the GPU using a curve instead of using a harsh power limit
You’ll lose around like 15% of performance while majorly saving on power and heat. It might also heavily prolong the lifespan of your GPU (I have torched 2 GPUs so far with 3D art rendering) by stopping it from turboing and going above 65c under full prolonged load.
I use my 4070 Ti Super for 3D art rendering and only performed benchmarks for that specific scenario so I have no idea about AI usage and the performance hit.
“Power” is volts * amps
Saying power scales linearly whilst saying voltage scales quadratically makes no sense.
I run my R9700 at the lowest settings the firmware allows. The power cap is lowered by 90W and the clock by 500MHz, and I also undervolted the GPU by 80 mV.
It doesn’t impact token generation, it is bottlenecked by memory bandwidth, not the GPU, but it does reduce prompt processing by 15-20%.
https://en.wikipedia.org/wiki/Voltage_and_frequency_scaling#Power
12900K P and E core voltage and frequency scaling behaviour
