Hello i am going to get my first PC(mainly for gaming). I will be wont be using it for any hardcore gaming more casual games. This is what i was thinking http://pcpartpicker.com/p/Jm6xbv I do have and OS for the system. I would not like to go over $600. Getting a system from ibuypower or something is not out of the picture either.
This build is only a little more and will be much much faster.
The FX is much faster. The memory is just as good and cheaper. You don't need a Black HDD. Much more powerful GPU. Better case. Better PSU. You don't need an optical drive or extra case fans.
Personally I wouldn't run wifi but if you must an internal PCIE card is much better.
i like how the NZXT source 210 Elite has a front facing HDD cage so air can pass though. if i were to make a couple suggestions....
i noticed you wanted to get a Red LED AF120. i would spend an extra $5 to get a 2-pack and put on on the bottom, and one in the front (bottom/front mount) and put the HDD in the top slot. that should keep things nice and cool.
