http://pcpartpicker.com/p/q3P7
This will be for mid to high end gaming and some EXTREME WORD EDITING.
Any suggestions/Comments would be great as i am very nervous about which parts to get
Thanks!
Thanks!
looks solid. I usually avoid Dell but for a monitor you are okay. To lazy to check but just make sure that the motherboard ports support the front ports on your case. Such as USB3 etc. I am sure it does though. Post some picks when you are done.
Also make sure CPU cooler has brackets for amd with it. probably does.
That build looks really nice only thing is you need to get 1866mhz for that cpu the amd processors really like fast memory.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231455&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=3938566&SID=
Also EXTREME WORD EDITING!? Sounds EXTREME
Hells yeah have you ever done some EXTREME WORD EDITING?
