What do you guys think about the fractal design define r4? Is this a good case? Is is quiet, roomy, cool, etc? I'm planning on getting this case unless there is a better case for around the same price range. Thanks.
Very quiet case, great build quality for the price, some plastic parts, but mostly steel. Roomy, yes, but no support for eATX motherboards :(
The airflow is not as good as the smaller Arc Midi R2, but it has plenty of options.
How would it compare to something like the NZXT phantom?
When I worked for TekSyndicate, I used an R4, and I quite liked it, a whole damn lot, lots of room inside, 140MM fan support, great airflow, I recommend it.
