I am looking into replacing my corsair H100i (I am having pump issues). I would like to stick to the closed loop coolers because I am comfortable with them and they work very well. I was looking over new egg and saw they have some 3 fan (360mm) radiator CLCs, are they a good step up from a 2 fan (240mm) radiator? Of them all I like the Deepcool Gamer Storm Captain 360. Mainly because the pump looks AWESOME. I can mount a 360mm radiator in my case easily. I know the included fans are terrible and I already have some great ones to replace them with, I just want your opinions on the radiator, pump, and other hardware. Thank you!
I think it's under-powered and under-performing, the Thermaltake water 3.0 ultimate is a bit better for the same price (also a 360mm rad) I will give the Deepcool this it is really badass looking. I have a water ult and I have to say my Cooler Master Neptune 280L is very close if not better in performance, Needless to say I'm not sold that a 360 radiator on a single part actually makes a difference. What I will say is the pump and fin density of the radiator makes all the difference. From what I've read Swiftec's AIOs are the best on the market by a fair margin they also sell a 360mm unit though it is hard to come by in the USA. (legal issues) My advice, If you must have that very sleek cool looking red thing buy it, otherwise get the Cooler Master it's cheaper and will perform better. If you really must have a 360 unit I have no complaints about the Thermaltake and it does perform very well (cooling a FX-9590) I just don't think the Captain is a very good product.
