Awhile ago I asked if this build ( http://pcpartpicker.com/p/AyC9 ) was okay. And it turned out okay.
But I wanna make sure it's totally okay before I order it tonight and a few other parts in a few days. My budget is right at $712 will raise a lil bit once I buy the rest of the parts.
Just need to know if you could swap out anything and change.
If this is okay, would everything fit together and work properly together ? Like the MOBO inside the case, enough cords, ect.
I would do this then its got a cooler for a little overclock and a little more power on the gpu and a psu with a very strong 12v rail to run a overclock and all the parts this is a very good build.
