Hey, it's my first time building a pc and I needed to know if this is going to work: http://pcpartpicker.com/p/1PHJ5 . I am willing to spend no more than $1200. I already got the case and the optical drive. The case is the Rosewill Galaxy-03 I'm including it in the link. I dont plan the overclock so i didnt include a cpu cooler. I will use it for gaming, console emulation and maybe in the future to render videos (maybe not) and I'm planning to use 2-Way crossfire with the card included in the link in the future (if I manage to get more budget). Please tell me what do you think of my build. Thanks in advance.
Better GPU for about the same.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202026
And maybe a better PSU (more watts or higher rating [one or the other])
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438005&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
or
http://www.microcenter.com/product/399158/CX_Series_CX750_750_Watt_ATX_12V_Power_Supply
i would go for a 64 bit win 8 or 7 and save ~$85 and if you are set on AMD
then get this motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E16813128514
and save another ~$60 now with the $145 you are saving get a better power supply and a better graphics card
PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817139051 $135
GPU OH MY GOD THIS ONE 4 free games and its a 7970 GHz edition
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150632 $20 over but well worth it
this would do if you dont want the first one
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161431 not $20 over
if you are not set on AMD
get a intel i5 3507k or 4670K have to get a different motherboard build below
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130645
Same GPU form above
http://pcpartpicker.com/p/1PJRF
Come on now I expected better from you. Joking. Anyways got a 1080p very good quality screen so you can see the difference in the computer. Hardware going to a bad screen will always look bad.
Upgraded the gpu to the 7950 which you can expect max on almost all games.
Beefed up the power supply for future crossfire and headroom.
I don't see a cpu cooler on your build which means I'm assuming you won't overclock. So I lowered the motherboard. The main difference between the 2 is how well the Sabertooth handles overclocks. The sound cards, ethernet chipsets, and bios are pretty much identical.
Unless you can state something specific you need from windows ultimate then you most likely don't need it. It won't result in any better performance.
Upgraded the ssd to a 256 gb Adata with better read write times.
Enjoy.
