This Capture Card Advice (Cables)
Hey Guys
Ive been given this contraption :-D
http://www.hauppauge.co.uk/site/products/data_hdpvr.html and now i have to somehow wire it to my monitor of choice to capture for me from my graphics card: (http://www.zotac.com/products/graphics-cards/geforce-700-series/gtx-760/product/gtx-760/detail/geforce-gtx-760-amp-edition-1.html)
I have the option of DVI-I (VGA) DVI-D or HDMI i need to convert one of these to component then from component to either one of the 3 outputs again.
I can assume VGA is out of the question as its an analog signal (DVI-I converted to VGA) so i have the choice of DVI-D or HDMI...
so basicly i cant work out what cable i need and how i can go around it.
i'm getting fed up with fraps and its lack of compatibility with Sony Vegas Pro 12 (Dropping frames and loosing audio randomly) so a friend has given this to me.
Any advice guys?
Tanks
Sean
No one? Really?
