Hey guys, I was wondering about upgrading my system. Currently i have the following
gtx 260 core 216 phenom 9950 BE EVGA 730a 3 gigs of ram (SHIT)
And i kind of wanted to get the new core i7s coming out (probably the 860). But I'm not sure if its worth the money, since its not THAT much better than my current cpu. Right now i have a shit case so i was either going to get a good gaming case, a cpu cooler, and some ram, or a new cpu mobo and ram. What do you think i should do?
Always try to get items that will go down the least in price over time. In this case its probably the case, cooler, and ram (since i've noticed ddr2 are starting to get more expensive). Also maybe consider Phenom II, you got a perfect mobo that can support it.
then ur only choice would probably be i7 920, or some new i5 that are within your budget. but still i'd get other stuff first, expect ram cause you might have to upgrade.
have you tried installing latest drivers? A lot of them will have updated it within the past few months to support the new phenom 2 CPUs. always check because amd CPUs are way better bang for ur buck. especially when the 955 is only $200.
Hmmm is there no bios upgrade that allows the phenom 2 to be used, as they fit in the AM2+ sockets? My 720 Black Edition did.
Would not go for any of the Core 2 stuff anymore as they are obsolete from the time the i5 and i7 stuff becomes available, unless you are buying secondhand then they could be a bargain!
If you have got the money then go for i5/i7 or get a phenom 2 based system for less.
not sure why anyone would suggest old, low bandwidth motherboards, ever. socket 775 is done, over with. getting a 775 cpu is like buying an am2 cpu right now, they're dying as we speak. I think im going to wait a while, till the i7s get nasty cheap when the i9's come out, or whatever happens. I just dont see a good purchase right now.
BTW, i declare phenom IIs the best overclocking cpus in history (or at least it ties the q6600). Took a friends from 3.0 to 3.7 on mediocre cooling in 1 try.
i disagree, there are physics exellerated for the gpu, and i saw a 20 fps increase in crysis when i went from 8800gts to gtx 260, i saw a 5 fps increase from an amd 4400+ 2.3 ghz dual core to a phenom 9950 2.6 ghz quad.
