Thinking about OCing
Hey all,
I was wondering if there was any real advantage to overclocking my CPU (AMD FX 6300).
My Mobo is the GA-970A-UD3 (Not a fan of it, but it gets the job done).
CPU cooler is the Xigmatek Dark Night Night Hawk Edition (quite a mouthful).
All I really do is play games and occasionally draw something up in Rhinoceros.
Would there be any point in me overclocking?
it seems to me already that your cooler is way Over Powered for your CPU im running the stock cooler with a max temp of 24C and min of 10C primarily sitting at 11C and no there is no need for you too overclock at all dont give into the nonsense it reduces the life of your CPU if you want it too go faster just set the turbo function but it's really not going to make much of a difference especially already running 3.5GHZ at 6 cores you don't need too i run multiple very demanding programs and have no need
NOTE: Overclocking will provide little to no FPS change
Hope this helped
Not really, but a mild overclock wouldn't really hurt. Manually lock your CPU on stock voltage, and bump up the clock speed as much as you can without adjusting voltage. This shouldn't really increase power of heat output that much, and you'd get a nice little increase in performance.
Overclocking your cpu might help more on cpu intensive games like BF4
There is a point in Oc'ingbut before you OC theres a checklist to fill out before you do it
1. Is youre CPU OC capable? Yes, all FX CPUs are unlocked
2. Is you're motherboard capable for OC? Yes it can OC and came with a good power design
>>>>>http://www.overclock.net/t/946407/amd-motherboards-vrm-info-database
3. Is your cooler up to the task? Yes, that's a great cooler and it will do the job just fine.
Potential drawbacks:
Higher Power Consumption
Higher Temps
You can get a decent OC out of your Mobo provided that you get some airflow to your vrm/NB heatsinks
Alright. I will wait for a game to come along that requires an OC to run smoothly.
AndreNugent - I got this CPU cooler due to the stock cooler being loud.
Thanks.
