So i made this build with gaming in mind on a not too crazy budget. If you have any suggestions to make it better, be my guest. I don't mind Nvidia over Radeon its just cheaper and just as fast.
pcpartpicker link : http://pcpartpicker.com/user/IncomingFUn/saved/1Xsz
Edit: This is the intended link not above http://pcpartpicker.com/user/IncomingFUn/saved/2vWn
http://pcpartpicker.com/p/1KXg9
Ok, so I am going to say sit and wait for AMD Hawaii GPUS. They are coming out this month. I want to say the 6300 is going to bottleneck a crossfire 7850. Ditch the extra 7850, upgrade to a 8350, and change the single 7850 to a R9 280. It should be out in 2 weeks.
Well I do need to save for the money! So that sounds like a good idea! Thanks
