Was looking at one of those builds possibly. Those are on the high end of what I wanted to spend right now. Which is better, why, and does something need to be changed? Also which will last longer and be easier to upgrade later? Thanks for your input.
The intel version is where i'd go for a starter PC. However, I think building your first PC as mitx might not be the best choice. That's FULL of frustrations waiting for you. You also don't NEED an SSD to start, it just makes your games load a lot faster. I wouldn't build a gaming PC without one, but it's still not a requirement.
DX12 is probably going to end up more widely adopted then gameworks though, and the current gen AMD cards seem to get a pretty big advantage there compared to maxwell cards
I would like to say "Welcome to the club!" While i don't have the time right now to do a whole pcpartpicker build I agree with Streetguru's build for the most part (case is personal preference). If you are going to get windows I suggest getting it from Kinguin as Paul's Hardware suggested (retail key there is like $40 iirc).
Read somewhere that having 2 4g memory sticks is better than 1 8g stick. I forget where I read it think they said it would be faster. Is that true? Also if I got rid of the monitor I could use my tv but I would have to go with a wireless keyboard/mouse setup and also would need to connect to Internet via wifi since router would be in opposite room. Would that work for gaming?
Apparently for skylake in CPU bound situations it can help, maybe 5% more performance or so in games, but getting a single 8gb stick makes upgrading to 16gbs much easier later on.
Also I'd avoid a grey market key, and just find windows in a back alley somewhere if you're trying to save money as it saves you additional money.
Thanks what about going wireless? I've read not to do it because of latency/lag issues but Xbox one seems to run fine? If I'll have constant lag issues I'll get monitor and just go with everything wired
@Keebler Streetguru is right about the ram. Skylake uses a dual-channel interface with the ram, so 2 sticks is a little better than 1. Something like X99 is quad-channel, and 4 sticks are usually better. But if you plan on upgrading the ram in a year when you might need it for big games, buyng 1 extra stick of 8gb is cheaper. But if you plan on running the gtx960, 8gb might be all you'll ever need. The way microsoft is trying to dumb down pc gaming instead of increasing what the xbone can do, that 8gb might last you until 2030.
http://pcpartpicker.com/p/8ZWLvK That is what I have come up its after y'alls advice. Someone did say ssd drive isn't necessary in first build. What advantages are there when gaming to having this ssd drive and what would the disadvantages be? Thanks for all your input and help.
Advantages of an ssd are all in the load times (which i don't find to be stupidly long in my rig without one yet). You're not going to see any benefit in the way of fps. Yes an ssd is a purely frivolous addition but many people (either from not knowing or being very highly impatient) will argue its necessity.
-No SSD -Larger than Micro ATX -Smaller Monitor (21.5") -$936
For a gaming PC I really recommend putting a significant portion of the budget on the video card. This is really where the rubber meets the road imo. So long as the rest of the system is adequate, it all comes down to the GPU in games.
The case I picked is the one I currently use. It is of relatively good quality, and has a lot of features that are found on more expensive options.
I changed the motherboard. Which one would work better for my build and playing games like crisis. Is the more expensive motherboard a waste of money in this build?
The fetures of the motherboard aren't really things that will improve gaming performance there just more sata ports and usb 3.0 and a slightly better motherboard heat sink. I modified this build a bit and went with a much better power supply.
