Ugh, tired of these cables just knotted up like this. I need a fix! I looked at braided sleeving but that stuff is expensive, plus it is too thin to put over the usb connector and audio jacks. Does anyone have a fix for me that is cheap and will work?. Thanks in advance.
Change the cable, and change the way you roll them, use the inside outside method (IIRC). And as for the sleeving, it's cheap.
Maybe im looking in the wrong places to find cable sleeving, are there cheaper places like dedicated stores for this stuff?
edit; haff in is .99 cents
http://www.xoxide.com/sleevingkits.html
boom
