Never get an Apevia PSU. Get Antec, SeaSonic, XFX or Corsair.
I don't think that mobo will support new Vishera CPUs, even though it says so on the website. Get something like an Asus M5A97 R2.0 or just any mobo with a 970( or 97) in the name or 990FX( or 990X) in it.
Not bad specs, though I'd recomend cutting back on a couple things to get a better CPU, an i5 2500k or 3570k. The PSU is a bit overkill, you're not going to use anything near 700W, 500-600W might be more appropriate. I don't know if it's 80 plus, but if it's not then getting one that is is important. If you want to cut costs then you might want to get a cheaper case as well .
