i dont own the case nor do i have the plan to buy it, but it seems like a very bad thermal design. i mean the cable management seems wonderful. however cutting off the gpu from needed intake and an exhaust fan above it seems like a bad plan. is it a good case or just an expensive nice case to look at?
The GPU is not cut off. Â First off, double slot GPU's exhaust air out themselves, how is there supposed to be room for an exhaust fan where all your cards are? Â Second, it's not cut off from intake. Â Part of the front 140mm fan blows into the GPU chamber. Â Then not to mention there is a mounting bracket at the back end of the 5.25 inch drive bays for a 120mm fan, and that can be slid from the top of the case down to 2/3 of the way(which is the GPU chamber). Â And then there is the huge 230mm fan on the side panel blowing onto the GPUs(there is ventilation on the side of the GPU chamber).
thanks for the explanation, however just to clarify i meant just above my gpu about 1 1/2 inches there is an exhaust fan in my case.
