I am looking to upgrade my chassis to get a cleaner look and better airflow.
Some opinions and experiences by owners of that case would be really helpful, especially looking at the fan controll of that case. According to the pictures found online, it would fit my needs but I do not want to spend money on overpriced boxes. Price does not matter as much, I just want to be sure.
I'm on my second build in that case, there is really nothing bad I can say about it except it is a heavy case and having a handle on one side (not centered) makes it awkward to pick up when full loaded.
The fan control does work but it's nothing special just a button on the top of the case to control the speed and another button to control the color, neither of these functions hold their settings when the computer is turned off and must be reset at every boot up, not a issue for me since my PC runs 24-7.
Okay, thanks.
I know you didn't ask but....lol
The case is very nice, cable management is very good, the hot-swap bays are well made although mounting drives to the trays is kinda' a PIA, I have a Corsair H100 mounted in the top and a 1050w PSU mounted in the bottom and there is still a lot of room, full length GPUs are no problem, the case is very well made but don't waste your time with the headphone mount on the side, my fell off every time I bumped into it with my leg until I just took it off and put the headphones on top of the case. Air flow is good as are in-case temperatures with the stock fans, all the intakes are filtered, fan noise is minimal because of the big 200mm fans......in my opinion it's a tank.
Then I will get myself a tank of a case! Thanks for your time :)
