Thermaltake commander MS/I case and intel DHH7KS Mobo
guys my case comes with a pre installed screw that looks like a standoff in the middle but its really not a standoff and i dont know how to install a screw over it. help. the case comes with 2 standoffs in the bag of screws. also i need help because the io shield wont fit i tried fitting it for over 30 mins literally. help me guys pleeeaaaassseee !
first of all calm down,i actually have the same case and i had the same problems :) you dont need to screw anything on that standoff its made to align your MOBO to the center of the case,and you will see some arches on the motherboard tray with screw holes,believe it or not these are the ''standoffs'',you must screw the motherboard on these arches,they replace the standoffs.
thank you so much youre a life saver man. i wish this was written in the manual. any ideas about the io shield ?
yeah they dont picture this "feature" on the manual,i nearly smashed the case to bits in frustration. now for the I/O shield i do remember it was actually harder than most cases to attach it,i had to apply some pressure on both sides until it fit,the interesting thing is that it didnt "click" like in most cases,also its pretty obvious but the i/o shield goes first than the motherboard im pretty sure you already know this but its always good to remember :) gl man
