same cpu cooler, $2 difference or am i missing something? they have “Thermalright Direct” and “Thermalright Direct 2” just seems weird
edit cant get the matching colors to thumbnail but price difference stands
normal amazon result link
Buy Thermalright Peerless Assassin 120 SE ARGB White CPU Air Cooler, 6 Heat Pipes Cooler, Dual 120mm C12CW-S PWM Fan, Aluminium Heatsink Cover, AGHP Technology, for AMD AM4 AM5/Intel 1700/1150/1151/1200: CPU Cooling Fans - Amazon.com ✓ FREE DELIVERY...
$34.29
pcpartpicker link
Buy Thermalright Peerless Assassin 120 SE CPU Air Cooler, Dual Tower 6 Heat Pipe, Dual 120mm TL-C12C PWM CPU Fan, for AMD AM4/AM5/Intel LGA 1700/1150/1151/1200, AGHP Technology, Aluminium Heatsink Cover: CPU Cooling Fans - Amazon.com ✓ FREE DELIVERY...
$34.90
From my perspective its only showing a $0.61 difference and that can be down to rgb vs no rgb!
Just one person’s perspective!
Two different SKUs , and as @trickkynickk said, they look like two different products ?
Different SKU’s and smol diff in price for me.
Maybe Bezos is gauging you OP?
Amazon Italy has all of them under one SKU, but then you can choose between black, white, no rgb, rgb, and se/no se …
Thermalright has three or four official Amazon seller’s accounts for whatever reason and they’ve been known to do things like this. Just buy from whichever account is cheaper.
thanks for confirming ewasted, i think i didnt describe what was happening well enough so heres a side by side
$34.29 vs $36.90
The different # of reviews makes me think it’s a completely different listing.
system
Closed
July 18, 2024, 6:54pm
9
