Howdy, all! I recently built a Threadripper Pro 5955wx system with a WRX80D8-2T, Dynatron T17 using Artic Silver 5 thermal paste.
I’m not doing any overclocking, just running high load with default settings using stress-ng at 75% CPU utilization using all 32 cores over 10 minutes. During the test I see moderate/significant thermal throttling as the CPU goes over 90°C to the point where the CPU frequency drops below 1GHz. The fan is maxed at 11,000 RPM during the test. Ambient temperature is about 27°C. During the test the CPU is running at ~232W.
Using fewer cores, I see much less throttling or no throttling, running at 4.5Ghz boost most of the time.
The cooler is rated as 280W, same as the CPU’s 280W TDP. I get it’s not an exact science, but I figured the 2U cooler would be enough to keep things cool under 100% load at least to sustain the base clock. Are my expectations wrong?
My first thought is wow! You must have something seriously wrong in config or set up.
The normal things
Obviously check cpu cooler, proper thin evenly distributed thermal paste and not much pump out (thermal grizzly kryonaut extreme example or noctua ht1 and finger paste it lightly evenly across whole surface avoiding the blog in the center technique)
Then if it’s still baking, replace cooler, but make sure the copper bottom footprint covers the whole cpu as these chips have a larger die distribution
No copper full cpu coverage? Get a different cooler
Then in the bios make sure you don’t have all core max etc and in os make sure your power management is 0% for minimum and 100% for maximum
Proper Bios config has more to do with proper performance than anything
Lastly, also obviously, make sure you don’t have a bug or a runaway app. Trim all services, get down to barebone to necessary only things in the back ground
Instal Siv (system information viewer)
And see what cpu activity has what ghz and which cores are being tasked including ram threads, at least “See what is going on”
Get rid of any auto run apps and make sure you have purged all ghost devices
That threadripper is a beast of a cpu! All threadrippers run hot at load. Watts are not everything mind you. That is a lot of cores running and if running at 75 percent that is still a lot of work being done.
My old 8350 runs like a heater at a lot of watts as well but can still keep it cool with a much lesser cpu cooler…why you ask. 8 cores vs Processor count 16/Processor Core Count 32
Watts of let’s say 200 on a 8 instead of 200 on a 16/32 is a big difference
Thanks, looking at some alternative coolers now. Should I stick to air coolers, or look at AIO liquid coolers?
I’m finding the 2U might be limiting the ability of the air cooler. 4U coolers seem to perform much better from what I’m reading. Seeing some liquid options in 2U might get better cooling with a large radiator.
Also, I reached out to dynatron support, if they say the T17 cooler should support this, then maybe I’ve got a defective part.
I’d look at custom loops too. 5U dual tower air tops out ~250 W or so on AM4/AM5/LGA1700. While TR4’s larger size enables higher power, both air and AIO options for the socket are limited and it’s unlikely a 2U case can accommodate a 360 or 420 rad, meaning the natural solution to me feels more like a waterblock and external rad.
You can probably gain some margin changing from Arctic Silver 5 to TF8.
