Thermal paste application
Since I'm going to replace my GPU's thermal paste, I was wondering what your perferred application method is. I am/was going to use the "line" method, because of the rectangle shape of the GPU, but I'm open to suggestions.
This worked fine for me. Used slightly more.
Thanks for the link. I've heard as well that too much thermal paste shouldn't be an issue.
I'm partial to the Kentucky way myself.
I used that and it's been working wonders on my 8350. Room is nice and toasty. :D
too much thermal paste is only a problem if the thermal paste is conductive, which is rare these days and not a good idea anyways unless you go liquid metal which is crazy and a rabbit trail. use non conductive and use as much as you want.
roger wilco
So, I reapplied the termal paste according to @w.meri's description xD and I experience a difference of about 20°C. In the end, it was definitely worth it.
20 degrees?
Sounds like the paste wasn't making good contact the first time around.
The difference between decent thermal compound is only ever a couple of degrees (as in 1-2 degrees), so the difference in application should be even less.
Generally people recommend a pea, line, x, grain of rice or similar shape. Most people agree that letting the heat sink spread the paste is best, and it is recommended to avoid the business-card method.
This asthonished me too, but I've tested it at about the same room temperature, therefore I believe my metrics are right. (There are others who have reported that the experienced a 20° difference as well on a similar card, like the MSI 290x)
I do an H pattern then put a dot in the 2 empty spaces.
For CPU yes this is right. Generally you don't want to clean up an extra mess or god forbid get any down into the socket. A CPU, unlike the GPU, has a heatsink on it already to both protect the processor and allow a wider area for heat transfer from the processor to the cooler. Because a GPU doesn't have that lid on it people generally use a little more than they would for a cpu to ensure full coverage of the die.
Yeah, I should probably have said that too.
Generally not enough thermal compound is bad, but too much isn't (unless it's conductive or gets in a socket or something).
For GPUs it is different, but it is still advised to avoid the business-card method.
