It's almost as small as the Wii but it's light years ahead of it. :3
This build will use an In Win BP655 and is intended for only APUs due to it's tiny form factor. One thing I like about this case is that it has 5.25" Drive Bays and 3.5" bays.
CPU: AMD A10 7850K
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1535050
CPU COOLER: Noctua L9A
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608030
RAM: G. Skill Ares Series 8GB DDR3 2400
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231665
HDD: WD Blue 1TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
MOBO: AsRock FM2A88X-ITX FM2+
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157464
PSU: Seasonic 300W 80 Plus Bronze TFX Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151090
OS: Windows 8.1
Upgrades:
You can install a Sapphire 100357LP Radeon 7750 or if it can fit a MSI GTX 760 ITX.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202002
