Oh no that’s fine I know how to use checkinstall. The permission problems I’m having a related to the permissions required for Qemu. Make install requires sudo and also requires a couple of commands in a row to actually install.
Nope. I was sure it was going to work though.
I’m still getting this
What is recommended for creating .rpm packages from source for Fedora et al? checkinstall
is no longer available from Fedora repos.
Is that from git? Is that an rc version.
Mine just says 3.0.0
Is there a way to show the GPU clock speed? Not sure my GPU is clocking up to the correct speed.
I have used “sudo lshw -C display” - But that just shows the downclock of 33mhz
GPU = AMD R9 290
Fedora would use rpmbuild.
Hmm rpmbuild process looks quite a bit more involved.
It’s from the macOs branch
And the exact same problem and solution upon upgrading to nvidia driver 410.66. Does no one else have this issue?
Well, if you already haven’t solved this, maybe you can make install
and just see what it does on your system (like where it copies it’s files or something) and remove all that. I don’t promise anything, but it might work.
You can also do which
to each qemu-whatever in your system to see where are the executables stored and delete them.
Also, not providing an uninstall target is kind of bad, you should file a bug or something to get that fixed.
Is there still no native VNC server in Fedora with Wayland?
I don’t usually use VNC on Linux but I have an instance where I want to. There’s no option in Fedora 28 under sharing (where I think it was/is supposed to be), and when I googled it there is conflicting info about VNC on Wayland.
X11 over ssh
On Fedora 28, sudo dnf update
is showing
Failed to synchronize cache for repo ‘virtualbox’, disabling
What’s wrong?
I have the following .repo file in /etc/yum.repos.d/
[virtualbox]
name=Fedora $releasever - $basearch - VirtualBox
baseurl=http://download.virtualbox.org/virtualbox/rpm/fedora/$releasever/$basearch
enabled=1
gpgcheck=1
repo_gpgcheck=1
gpgkey=https://www.virtualbox.org/download/oracle_vbox.asc
EDIT: verbose details with sudo dnf update -v
Cannot download ‘http://download.virtualbox.org/virtualbox/rpm/fedora/28/x86_64’: Yum repo downloading error: Downloading error(s): repodata/8797acb2bdc4a098c1ebade2f11ff827324fddb42bd09973fef46490574f617f-primary.xml.gz - Cannot download, all mirrors were already tried without success.
But I can navigate and download that site/file from a browser.
EDIT2: The workaround of changing the baseurl in the repo file gets rid of the problem:
baseurl=https://download.virtualbox.org/virtualbox/rpm/fedora/26/$basearch
What is the best way to go about tweaking GPU settings? Like core clock, voltage, power limit?
I’m new to Linux and running Ubutnu 18.04. I have an AMD R9 290 so have to use the AMD proprietary drivers.
I am used to MSI Afterburner on Windows where it’s just some easy sliders and you’re set.
For AMD there is no easy tool like that which I am aware of. I was able to find this, which does it with the Open Source AMDGPU driver.
https://linuxconfig.org/overclock-your-radeon-gpu-with-amdgpu
Does anyone know of a reasonable way to open DRM protected Kindle textbooks in Linux? I’m on Ubuntu, and I need to open a textbook. Cloud reader doesn’t work. WINE doesn’t want to work. Calibre can’t open it obviously, because I can’t even download it.
Am I stuck trying to do this with a VM?
This was the first thing that came up when I searched.
https://linuxconfig.org/calibre-drm-removal-for-ebooks-on-linux
This is probably some sort of eula gray area.
I tried doing this in the past and I ended up doing it in a VM because all of the linux methods were so poorly documented.
That seems like the easiest solution, unfortunately. Not exactly an efficient solution. My poor 3570k is starting to show its age, I wonder if a Xeon would handle the VM better.
I guess I’ve paid for it, as long as I delete it after my rental is up…It is kind of a gray area, I guess. So annoying that piracy is often the easiest solution.
I wouldnt consider it piracy because you’re not stealing. You are, however, circumventing drm.
