The small linux problem thread
Some windows programs “i won’t need anymore xD” the other is games from GOG, steam etc.
Today I switched to Linux Fedora because Windows decided to bluescreen.
Well, congrats on the switch!
Yeah, I’d just toss those mounts in /media.
On a related note to this, When I first installed Ubuntu 16.04, all my drives were mounted in /media, and were designated by the names I had given the drives. (exp: games, windows, media)
But since I’ve been on 18.04 The drives have all been mounted to /mnt/“uuid number.”
Is this a switch they did for Ubuntu or did I do something. The first way I describe was easy to know which drives were which. But now I’m having to keep a post-it-note to know which drives are what, cause some of the drive uuid’s are hella long.
Was this an Ubuntu change, or did I screw something up when I installed 18.04?
Did an sudo apt-get update
sudo apt-get upgrade
Seems to have borked my system
Is there a way to roll back? I haven’t set up a snapshot unfortunately
Ubuntu 18.04
I am getting the error kernel: ipmi:dmi: Invalid IPMI type: 0 on boot and in dmesg.
Running ubuntu 18.04 with kernel 4.18 on a supermicro x8dtl-i motherboard.
My motherboard does not have ipmi, but there are other x8dtl* boards that do. Is there a way to disable ipmi in the kernel?
set the default output to HDMI instead of DP?
Hello.
I am trying to get remote desktop access to my remotely Ubutu 18.04 machine.
I have I have a working Teamviewer and access via open ssh.
While I connect via X11rdp the session hangs, no error on the windows client side.
Any ideas ?
Do you have the x11rdp package installed on remote machine you are accessing?
My guess would be a misordered fstab. Typically you want to use the uuid to keep track of drives to mount them in the same location, but on a human readable mount point. You probably just used the uuid twice.
Short answer: yes.
Long answer: you really don’t want to roll back unless absolutely nothing boots properly.
Try looking in /var/log/syslog for starters, and see what went wrong. A little more detail can help us give you info for how to fix what broke.
Note that the following instructions are for a SysV system, and I’m not 100% that they work the same on your SystemD system:
grep initdefault etc/inittab
Find the number, that’ your run level. (Probably 5 or 3)
Assuming 5:
mv /etc/rc.d/rc5.d/K74ipmi /backuplocation
OR:
Go in to the following file and set these options to no:
vim /etc/sysconfig/ipmi
IPMI_SI=no
DEV_IPMI=no
IPMI_WATCHDOG=no
Let us know if you have issues. Good luck.
I didn’t do anything. This is how Ubuntu set them up. I haven’t touched fstab at all.
In that case, you could use the UUID to mount your drives to mountpoint called games, windows and media by adding a few lines to fstab (if they aren’t already in fstab). Let me know if you need help with this and I’ll provide a few examples.
I don’t use Ubuntu, but it’s possible that it parsed the drives and added them to fstab in the way it thought best, which means it could have changed for a number of reasons.
My problem is this. I built qemu from source with make install. But now there doesn’t seem to be a make uninstall function and I need to reinstall it because it’s behaving weirdly. How do I uninstall it completely.
sudo apt remove qemu*
hasn’t worked
sudo apt-get remove qemu* should work.
I tried that too and qemu-system-x86_64 --version still works. I think it’s because I built it from source on top of installing it from apt-get
apt isn’t going to uninstall it since you didn’t use the package manager to install it. Instead of using make install, make it into a .deb file then use apt for installation…then you can uninstall it with apt if needed.
huh. TIL.
That’s actually a good idea.
I’m trying it right now but running into permission issues.
I Will come back with the results as soon I get it working.
