Any time.
I have an older 2560x1600 monitor that reports its native resolution as 1280x800. The display has no built-in scaler. Under X Windows, I can only get those two resolutions. I thought Iād try using xrandr to enable GPU display scaling, like so:
$ xrandr --output "DisplayPort-2" --set "scaling mode" "Full aspect"
However, this accomplishes nothing; I still only see 1280x800 and 2560x1600 as the available display resolutions.
Is there any way to get more resolutions under Linux? Windows has a full range of available screen sizes.
What GPU are you using and what DE are you using?
If you have nvidia, do you only see those two in this list in nvidia-settings?
Vega 56 with XFCE on Fedora 28.
Hey guys,
I am running a vserver and have a rather weird problem. The server has little over 700 GB hdd space and I just found out that a folder ā/dev/ploop54996p1ā is using 93% of the space. In numbers this folder is 713 576.15 MB out of 766 553.01 MB big. I have no clue what this folder is for.
The server is running Plesk on Ubuntu 14.04
Does someone know why it takes up all the space? What is this etc.? Can I delete it?
Thanks and kisses in advance
Why donāt you look inside to see if itās got important data.
Not familiar with that naming convention, if you want to dump the tree, that would be nice.
Recommended best Kernel for gaming on AMD R9 290?
Well, it turns out that it were Plesk backups of a website that I run on the server. Backups for every day for half a year
Iām trying to force Debian 9 to use eth0 for my ethernet NIC instead of the random device name it assigns. I added the following to /etc/default/grub:
GRUB_CMDLINE_LINUX_DEFAULT=ānet.ifnames=0 biosdevname=0 quietā
and then ran āsudo grub-updateā. That worked, but in a weirdly incomplete way. Now the ethernet interface wonāt autostart at boot. However, if I run ā/sbin/ifconfig eth0 upā after booting, the NIC comes up fine. Iāve also added the following to /etc/network/interfaces:
auto eth0
iface eth0 inet static
address 192.168.1.80
netmask 255.255.255.0
gateway 192.168.1.1
But that still doesnāt help. For now, Iāve added the necessary commands to /etc/rc.local, which is pretty kludge-y.
What happens if you add allow-hotplug eth0
Alternatively, try messing with systemd and try something like systemctl enable [email protected]
@SesameStreetThug Thanks, allow-hotplug eth0 worked perfectly. Though curiously NetworkManager is very upset about the whole eth0 thing and refuses to manage the connection. Not a biggieā¦
Are you using for a desktop or server? I typically avoid NetworkManager for servers.
I installed Debian in a desktop configuration, then āupgradedā it to a Proxmox (non-subscription) install. I didnāt consider that installing it in a desktop configuration would mess with the networking.
Iām pretty sure Debian doesnāt distinguish between Desktop and Server as it applies to networking. At work I typically use systemd-networkd (sue me systemd haters) and I donāt run into issues with it, there are other options too such as Wicked. At this point it shouldnāt matter as it seems youāve gotten it working.
Just for the record, NetworkManager did cause me a bit more grief. /etc/resolv.conf was symlinked to some file in the /etc/NetworkManager directories, which prevented the server from finding anything not on the local subnet. I unlinked it and created a new resolv.conf from scratch.
Thatās not the first issue Iāve had with NetworkManager. Seems to have its fingers in too many piesā¦
EDIT: Would it be a wise idea to remove NetworkManager (ie, apt-get remove network-manager)? Iām afraid an update might undo some of my changes. Is there any need to replace it with something else?
If you donāt want to use NetworkManager just disable it with systemD
systemctl disable NetworkManager
I would avoid removing the package, some other things may list it as a dependency.
I am using Ubuntu and an AMD R9 290
I am using the bundled open source AMD driver.
How can I see what version I am on and what/if there are any updates/newer versions
The driver is packed with the kernel. Theres no updates that YOU need to worry about. If theres a driver update, it cowes in as a kernel update.
I understand that it is bundled with the Kernel but I was wondering if there was an easy way to check what current driver I am on.
Another question I have is that my machine seems to slow down if left on for a number of days. A reboot fully sorts it out but it feels like that when I close programs that they donāt actually close.
Is this something Linux does? Is there a way to combat this?
Linux newbie BTW
So ever since i switched to debian, my monitor will not turn on when i attempt to wake it up.
The PC is not sleeping it just turns off the monitor after a set amount of time, but pressing anything or moving the mouse will not wake the monitor up.
When i turn the monitor off and back on it works fine again, googled a fair bit but was unable to find a solution.
