A clue:
https://solus-project.com/forums/viewtopic.php?t=2630
Appears to be related to udisks2 defaulting to /run/media
Yeah itās a Gnome thing. I never noticed it before.
I donāt see why it would. The default location for a machine in virtual box is located in the home folder of the user that creates it.
Unless these are VMās you want other users to access.
The link I posted says Ubuntu patched it so everything mounts to /media like normal. I wonder what allās involved with that. I mean, itās not really hurting anything. But it does seem to go against convention or spec.
Nope, no one else needs access. Iāll probably just mount the drives in my home directory.
Anyone know of a good, fast USB WiFi adapter for Linux? Preferably one that is plug-and-play, but not necessary.
I ask because my Panda adapter recently bugged out so I bought a Netgear one and it works greatā¦ in Windows. Iām seeing about 40mbps download speed increase.
Used to have:
Now have:
The Panda one was plug-and-play, which was really nice, but I donāt really want to buy another one when Iām getting much better performance (in Windows) out of one thatās not much more expensive. For Linux Iām sharing the WiFi connection over ethernet from my laptop, but itās pretty old and itās slooow in comparison.
The problem is Solus doesnāt seem to play nice with Netgear (https://dev.solus-project.com/T5657), so Iām looking at getting a different adapter. I donāt really want to switch distros mostly because Solus is the easiest to set up with my hardware, and a few other reasons.
So, an update to the VM image transfer to SSD project, in case anyone wants to do that but doesnāt know how (probably not very many people).
Original problem and goal: move VM image (.img file in my case, would work with qcow too) to an SSD, but image was larger than the SSD.
Quick high level overview of the process:
Copy original VM image to a new location, donāt do any of this on the original file.
Boot copied VM image file. Clean up junk files, uninstall unneeded games and software, defragment. Shrink NTFS partition as much as you can from within Windows using Disk Management. Will probably have to reboot several times to move āunmovableā files.
Shut down VM and follow instructions at this link: the link
dd the new image file to SSD
Add the SSD to your VM via this link: the other link
Profit
I am now booting my VM off of the SSD. It is very nice.
A somewhat annoying problem
I want to get my line-in audio port to be a loopback device - as in playback audio from it directly to my headpones and I also want my mic in port to remain independent and not be part of the loopback device.
Hereās the problem, pulseuaudio works with sources and sinks and for some magic reason, all the input ports are part of a one source.
pactl list sinks short
0 combined module-combine-sink.c s32le 2ch 48000Hz RUNNING
1 alsa_output.pci-0000_29_00.3.analog-stereo module-alsa-card.c s32le 2ch 48000Hz RUNNING
pactl list sources
Source #3
State: SUSPENDED
Description: Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo
Driver: module-alsa-card.c
Sample Specification: s32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 10
Mute: no
Volume: front-left: 15073 / 23% / -38.30 dB, front-right: 15073 / 23% / -38.30 dB
balance 0.00
Base Volume: 6554 / 10% / -60.00 dB
Monitor of Sink: n/a
Latency: 0 usec, configured 0 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "32"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC1220 Analog"
alsa.id = "ALC1220 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "2"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfe600000 irq 58"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:29:00.3"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:29:00.3/sound/card2"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1457"
device.product.name = "Family 17h (Models 00h-0fh) HD Audio Controller"
device.string = "front:2"
device.buffering.buffer_size = "768000"
device.buffering.fragment_size = "384000"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo"
alsa.mixer_name = "Realtek ALC1220"
alsa.components = "HDA:10ec1220,18491221,00100003"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
analog-input-front-mic: Front Microphone (priority: 8500, not available)
analog-input-rear-mic: Rear Microphone (priority: 8200, available)
analog-input-linein: Line In (priority: 8100, available)
Active Port: analog-input-rear-mic
Formats:
pcm
I want to do this
pactl load-module module-loopback latency_msec=1 source=3 sink=1
Essentially send input from source 3 port 3 (line in) directly to line-out, except It only accepts an entire source with multiple ports, I want to just loopback the line-in portā¦
Are channels here perhaps referring to ports?
Does anyone know how to do this with pulseaudio, is it even possible? Or do I need to create a virtual sink from the line in source port and mix it with sink 1?
All in all this seems like Pulseaudio Programmer idiocy.
Nobody asked for this extra headache just to shuffle around input sources.
Iām guessing a possible way to do this may be to module-remap-source
and split
the source out into multiple sources based on itās ports?
Maybe thatās also not possible since I only have a limited amount of ADās
02-00: ALC1220 Analog : ALC1220 Analog : playback 1 : capture 1
02-01: ALC1220 Digital : ALC1220 Digital : playback 1
02-02: ALC1220 Alt Analog : ALC1220 Alt Analog : capture 1
So mixing anyone?
Itās a lost cause. Mixing in pulseaudio is idiotic.
Use alsa directly or install jack and get it done with.
Iām having to run the following command in terminal after every reboot - Is it possible to get it to run automatically?
sudo -i
echo performance | tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
you could put that line into your /etc/rc.d/rc.local fileā¦ I believe this does not work on systems with systemd, as systemd is different.
Their is a program out there called cpupower and you can use that program and systemctl to do what you want to do.
Iām trying to hook up an Apple Wireless Keyboard (model A1314) to my Fedora 28 Cinnamon Spin laptop. It connects, but all I can get out of it is numbers, as if I had added a bluetooth number pad. Iāve tried changing the keyboard layout to English (Macintosh) but, again, all I see are numbers (and the / and * characters.) It works OK in Windows, so I know the keyboard itself is functioning properly. Any suggestions?
EDIT: Solving this was so simple. I just turned off the numlock on my wired keyboard and the Apple keyboard started functioning properly. pfft.
EXCUSE ME
Ahem
Has anyone compiled Vim from source on Debian Stretch? I can do it on Ubuntu, Fedora, and Arch without issue. On Debian, after compiling, when I type vim
I get an error that it doesnāt exist.
Using this guide:
Iāve even tried which vim
before removing it, and using that path as the installation location when running configure
No idea why Iām such a failure
You may have to run it using itās complete path depending on where you installed it.
Thatās the thing, Iām pretty sure I installed it in /usr/local/share/vim
Iāll make a VM and perform a snapshop before compiling and see if I can figure it out.
Will revisit the path, though. Great idea! Thanks.
Its time to reinstall the OS On my desktop. It has been through every ubuntu upgrade since the 14.04 days, and its finally saying that it does not want to live anymore.
Which is too bad, because its going to live whether it likes it or not.
My problem: I have a large ZFS pool that hosts my home directory that I would like to keep around. If I reinstall the OS (I will likely switch to Fedora), does that mean I lose the ZFS pool?
As far as I know, when you start your install from the live usb you should get an option on the bottom where is says formatting and stuff? I think the first option is to install Ubuntu along side other installations?
Go down to the last one that says: (I think)
something else
And it will give you a choice to partition hard drives. When you have to repartition your home directory, choose change, then select format type, e.g.: ext4, then select where to mount. Tell it NOT to format it, and assign it to /home. You should retain all your home files. I think Iām right in this.
(Iāve installed Ubuntu way more times than I should have due to corrupt installs.)
Please anyone correct me if Iām wrong.
*Edited to reflect actual steps
Iām on Debian Sid. Compiling it rn, but, just informing, here the binary for vim was located at /usr/bin/vim (output of which vim
) but the $VIMRUNTIME was set to /usr/share/vim/vim81, so I guess it just isnāt the right directory to put into the prefix (maybe it is not in the $PATH.)
Well, thatās done. I ran configure
with --prefix=/home/user/.local
, and after running make
(and then the make install
) as per the guide my ~/.local/bin was promptly populated with vim binaries. If your installation finished without errors, I recommend dry-running make (sudo make -n install
) to see where the heck are those binaries going. Also, check the $PATH.
In the first ~12 lines there must be a line like cp vim [your prefix]/bin
, that must be where it is going to go when you run it for real.
Also, why is vim so damn bloated??
