When you say on of the above do you mean this? I do not know how to change /etc/profile, I have put the export commands there and also this command
[[ -f ~/.profile ]] && . ~/.profile to .bashrc to help .profile to be picked.
I do not know how to do a wrapper script.
UPDATE: I have appended /usr/local/texlive/2018/bin/x86_64-linux/ before the commands in TexStudio and it works. But it is not the right way, because Okular for instance cannot sync with TexStudio that way.
At first I tried puting $PATH instead of typing the full path and the output error of TeXstudio did not show the correct path. But when I type echo $PATH in terminal it returns the correct path. (By saying correct path I mean the default path but with an extra location of the latex installation at the beginning).
You place that in /usr/local/bin and chmod +x it, naming it whatever you want. From there, update the .desktop in /usr/share/applications/ for texstudio to call this script.
Iām having an issue setting up āshared foldersā with virtualbox. Iām using Manjaro KDE and have made a windows 10 VM and I want to shared my 4TB drive with the VM (cuz games) the folder it set to read only and refuses to change. any ideas?
also I cant add my steam library in manjaro either as it says it needs Executable rights, when it looks like it has themā¦
is there a way to resize screen resolution in linux (via Nvidia settings) like there is in windows? in windows I can check the box āresize desktopā and it will bring up arrows in all 4 corners of screen and slide bars to resize to fit screen.
Thanks again, guys, for suggesting disabling selinux. I mean, Iād rather not, but it allows lxc to work. Kinda sucky, but whatever.
So, setting up a Fedora container apparently does a super duper minimal install, which has absolutely nothing in it. No dnf, no sudo, no man, nothing. What do? Or, maybe Iām just not understanding the purpose of what I am doing? Or, I just have no idea in general and I should do some more research.
It seems like a lot of my questions lately are sort of out of the scope of a āsmall linux problemā and more into the ālarger, more complex linux problemā sort of territory. Hmm.
Yeah, adding dnf to that line totally installs dnf in the container. Super cool.
Also, I just spent a bunch of time going through that file. Wow. Lots of comments and thereās an rsync command linking to Fedora 20. May be out of date? Hence the reliance on yum I guess.
Centos works fine, though. Ubuntu threw some errors and didnāt install. But now I know I can go into the templates and make changes. Cool.
Now to figure out networking. Maybe later this weekend.
NAT/macvlan/bridging with libvirt/virt-manager was very frustrating for me. Thatās sort of why I started down the lxc route, to see if I can do it a bit easier and also use less host resources.
it was NTFS as im working on moving from windows 10 to manjaro. I changed the FS to ext4 and that seemed to fix my issue, thanks for your reply, i did some more digging after I posted and found out that people are heaving issue with virtualbox properly mounting ntfs drives when your host is linux based.
