Uh oh. At least you still have half.
Sorry to hear that. My Realtek NIC died on my 990FX back in Feb. I just now am accepting that I need an add in card for this Bulldozer build. Currently using a USB wifi stick.
I need RAM to go down in price so that I can build a Ryzen setup.
Just a note for anyone searchingā¦ And ill probably explain this wrong but my problem is fixedā¦
After updating the kernel to an unofficial version virtualbox will break. Installing Virtualbox from the ubuntu repo still uses virtualbox-dkms. Dpkg-reconfigure virtualbox-dkms and modprobe vboxdrv are useless.
Installing virtualbox from the virtualbox.org using the deb will update you to a version that is independent of the kernel modules fixing the problem. Iām currently on 5.2.16. Ubuntus version was 5.2.10-dfsg-6ubuntu18.04.1
You may have been able to dkms install
rather than dpkg-reconfigure
and it would have probably worked.
While im not going to break the golden rule and mess with something that works. Ill start a vm and try it out just to verify.
Break a vm, within a vm, lawl
actually, can i run virtualbox, within virtualbox?
If the forum turns inside out, youāll know something went wrong.
Nope, and this is as far as I take it.
sudo dkms install virtualbox/5.2.10
Creating symlink /var/lib/dkms/virtualbox/5.2.10/source ->
/usr/src/virtualbox-5.2.10
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
make -j8 KERNELRELEASE=4.17.9-041709-generic -C /lib/modules/4.17.9-041709-generic/build M=/var/lib/dkms/virtualbox/5.2.10/build.....(bad exit status: 2)
ERROR (dkms apport): kernel package linux-headers-4.17.9-041709-generic is not supported
Error! Bad return status for module build on kernel: 4.17.9-041709-generic (x86_64)
Consult /var/lib/dkms/virtualbox/5.2.10/build/make.log for more information.
iirc it only works when you hide the fact that its a VM
Seemed to work fine. Didnāt do anything special. The parent VM had amd-v enabled not sure if that matters.
But I wasnāt checking functionality, more interested in making it fail the same way mine did.
I have this really frustrating thing now for a whileā¦
Ubuntu 18.04 currently running, but had it beforeā¦
Ubuntu things that my monitor is a 27 inch 4K display, while in fact it is a 32 inch 4k, thatās the first thing thatās odd.
this doesnāt really bother me, but on a 100% scaling everything is tiny, the only other option Ubuntu gives me is 200% witch will be suitable for my 90 year old granddadā¦
soā¦ how do I get this on the right scale?
also, in Windows I run 150% scaling what would be absolute great if this scale would be possible on ubuntu.
Really basic question here. In the past, if I wanted to run a command at boot, I wouldāve dropped it in rc.local. But that has apparently gone bye-bye.
If I want to run a command (not a service/daemon!) at system startup, where do I put it in Fedora 28?
What WM/DE are you running?
Are you using Wayland or xorg?
rc.local should still work. I have not touched fedora in ages but rc.local works on debian SID ans Arch for me.
Most DEs allow you to run scripts and programa on startup as well.
I put the following in /etc/rc.local:
#!/bin/bash
/usr/bin/cpupower frequency-set --governor performance
/sbin/ifconfig >> /root/netconfig.txt
And thereās nothing in /root and CPU clock speed is still ~800MHz.
I am running xorg.
sorry iām a bit of a Linux noob.
Iā m just running Ubuntu 18.04 default. Currently a fresh install.
I have an ASUS Crosshair VI Hero with an 1800x, After building this system I went back to using Windows After watching Wendel on Linus Tech Tips a couple days ago I decided to play around with Ubuntu again. Ubuntu 18.04 does not have an option to Hibernate and when it puts my computer to sleep it will not wake from keyboard or mouse. I also ran into this on Windows but when using Hibernate and the Asmedia 3.1 USB ports it will wake up from Hibernation.
Any Advice?
Quick piece of mind question. Iām running an Ubuntu system with a Windows VM and a passed through GPU. The sound from the VM is quite scratchy and distorted.
I have it set up so it is almost perfect, but I wanted to throw an idea out there to maybe fix it. I was thinking about getting the cheapest sound card I could, passing it through, and then running a male/male 3.5mm cable out the headphone jack of the sound car into the line in on the motherboard for Ubuntu. Then allow that line in to be heard through the motherboard headphone out jack within Ubuntu. Basically letting you listen to the line in.
I usually put it in cron
I guess thatās one way to approach it. Still curious why rc.local isnāt working. Has it been deprecated in favor of systemd? It seems silly to create a service for a one-liner at boot.
Thanks for the suggestion, but there are two problems with that. For one, Iām using the Cinammon spin. For another Iād like to apply it at boot in case I donāt login immediately, or someone else logs in.
But I seem to have found a better solution. By disabling C-States and SpeedStep in the BIOS, I can force the CPU to run full tilt at all times.
