I am trying to setup WordPress for multi-website on my local server using a master domain. My master domain is shadowbanegames.org. I am following the instruction I found on Website for Students. I follow all the steps and have no problems until I come to the step about setting up a DNS server so Wordpress understands when I type shadowbangames.org or any of its subdomain which website page to display. So I find an instruction guide on how to set up a local Bind9 DNS Server called Whiteboard Coder. Now for my problem and the reason for posting in this section, I donāt think my local DNS Server is working because when I try and check to see if it is working, I use the dig t short @192.168.200.11 shadowbanegames.org the only response I get back from the Terminal is the Terminal prompt, meaning the DNS Server isnāt doing its job. Where I think the problem might lie is I donāt have the name server set up correctly so I will include a copy of my named.conf.options. named.conf.local and the three files that defined my zones.
named.conf.options
<acl goodclients {
192.168.200.0/24;
localhost;
localnets;
options {
directory ā/var/cache/bindā;
recursion yes;
allow-query { goodclients; };
forwarders {
1.1.1.1;
1.0.0.1;
forward only;
dnssec-validation auto;
auth-nxdomain no; # conform to RFC1035
listen-on-v6 { any; };
named.conf.local
zone "shadowbanegames.org" {
type master;
file "/etc/bind/zones/db.shadowbanegames.org";
zone ā10x13.comā {
type master;
file ā/etc/bind/zones/db.10x13.comā;
zone ā11.200.168.192.in-addr.arpaā {
type master;
file ā/etc/bind/zones/db.11.200.168.192ā; # 192.168.200.1/16 subnet
$TTL 900
@ IN SOA ns1.10x13.com. admin.10x13.com. (
1 ;
900 ;
900 ;
604800 ;
900) ;
;List Nameservers
IN NS ns1.ns1.10x13.com.
IN NS ns3.ns1.10x13.com.
;address to name mapping
astraelementor.shadowbanegames.org. IN A 192.168.200.10
test2.shadowbanegames.org. IN A 192.168.200.10
;Now for aliases
www IN CNAME shadowbanegames.org.
offtopic IN CNAME ghs.google.com.
db.10x13.com
$TTL 900
1 ;<serial-number>
900 ;<time-to-refresh>
900 ;<time-to-retry>
604800 ;<time-to-expire>
900) ;<minimum-TTL>
;List Nameservers
IN NS ns1.10x13.com.
IN NS ns3.10x13.com.
test1.10x13.com. IN A 192.168.200.10
test2.10x13.com. IN A 192.168.200.10
ns1.10x13.com. IN A 192.168.200.11
ns3.10x13.com. IN A 192.168.200.11
db.11.200.168.192
$TTL 900
2 ;
900 ;
900 ;
604800 ;
900) ;
; name servers
IN NS ns2.10x13.com.
; PTR Records
200.11 IN PTR ns1.10x13.com. ; 192.168.200.11
200.11 IN PTR ns2.10x13.com. ; 192.168.200.11
200.10 IN PTR test1.10x13.com. ; 192.168.200.11
200.10 IN PTR test2.10x13.com. ; 192.168.200.11
200.10 IN PTR astraelementot.shadowbanegames.org. ; 192.168.200.10
I also have included part of the latest error log.
07-May-2018 16:11:00.170 general: info: managed-keys-zone: journal file is out of date: removing journal file
07-May-2018 16:11:00.170 general: info: managed-keys-zone: loaded serial 22
07-May-2018 16:11:00.170 general: info: zone 0.in-addr.arpa/IN: loaded serial 1
07-May-2018 16:11:00.170 general: info: zone 127.in-addr.arpa/IN: loaded serial 1
07-May-2018 16:11:00.171 general: error: /etc/bind/zones/db.11.200.168.192:1: no current owner name
07-May-2018 16:11:00.171 general: error: zone 11.200.168.192.in-addr.arpa/IN: loading from master file /etc/bind/zones/db.11.200.168.192 failed: no owner
07-May-2018 16:11:00.171 general: error: zone 11.200.168.192.in-addr.arpa/IN: not loaded due to errors.
07-May-2018 16:11:00.171 general: info: zone 255.in-addr.arpa/IN: loaded serial 1
07-May-2018 16:11:00.171 general: info: zone 10x13.com/IN: loaded serial 1
07-May-2018 16:11:00.171 general: info: zone localhost/IN: loaded serial 2
07-May-2018 16:11:00.171 general: error: /etc/bind/zones/db.shadowbanegames.org:3: no current owner name
07-May-2018 16:11:00.171 general: error: zone shadowbanegames.org/IN: loading from master file /etc/bind/zones/db.shadowbanegames.org failed: no owner
07-May-2018 16:11:00.171 general: error: zone shadowbanegames.org/IN: not loaded due to errors.
07-May-2018 16:11:00.171 general: notice: all zones loaded
07-May-2018 16:11:00.171 general: notice: running
07-May-2018 16:11:00.171 notify: info: zone 10x13.com/IN: sending notifies (serial 1)
07-May-2018 16:11:04.606 queries: info: client 192.168.200.11#41988 (cdn.syndication.twimg.com): query: cdn.syndication.twimg.com IN A + (192.168.200.11)
07-May-2018 16:12:04.614 queries: info: client 192.168.200.11#41988 (cdn.syndication.twimg.com): query: cdn.syndication.twimg.com IN A + (192.168.200.11)
07-May-2018 16:12:15.447 queries: info: client 192.168.200.10#38488 (detectportal.firefox.com): query: detectportal.firefox.com IN A + (192.168.200.11)
07-May-2018 16:12:15.447 queries: info: client 192.168.200.10#38488 (detectportal.firefox.com): query: detectportal.firefox.com IN AAAA + (192.168.200.11)
07-May-2018 16:12:16.212 queries: info: client 192.168.200.10#38488 (www.linuxmint.com): query: www.linuxmint.com IN A + (192.168.200.11)
07-May-2018 16:12:16.212 queries: info: client 192.168.200.10#38488 (www.linuxmint.com): query: www.linuxmint.com IN AAAA + (192.168.200.11)
07-May-2018 16:12:16.501 queries: info: client 192.168.200.10#38488 (getpocket.cdn.mozilla.net): query: getpocket.cdn.mozilla.net IN A + (192.168.200.11)
07-May-2018 16:12:16.501 queries: info: client 192.168.200.10#38488 (getpocket.cdn.mozilla.net): query: getpocket.cdn.mozilla.net IN AAAA + (192.168.200.11)
07-May-2018 16:12:16.700 queries: info: client 192.168.200.10#38488 (ocsp.int-x3.letsencrypt.org): query: ocsp.int-x3.letsencrypt.org IN AAAA + (192.168.200.$
07-May-2018 16:12:16.700 queries: info: client 192.168.200.10#38488 (ocsp.int-x3.letsencrypt.org): query: ocsp.int-x3.letsencrypt.org IN A + (192.168.200.11)
07-May-2018 16:12:16.867 queries: info: client 192.168.200.10#38488 (tiles.services.mozilla.com): query: tiles.services.mozilla.com IN AAAA + (192.168.200.11)
07-May-2018 16:12:16.867 queries: info: client 192.168.200.10#38488 (tiles.services.mozilla.com): query: tiles.services.mozilla.com IN A + (192.168.200.11)
07-May-2018 16:12:16.946 queries: info: client 192.168.200.10#38488 (www.google.com): query: www.google.com IN AAAA + (192.168.200.11)
07-May-2018 16:12:16.946 queries: info: client 192.168.200.10#38488 (www.google.com): query: www.google.com IN A + (192.168.200.11)
08-May-2018 10:24:06.333 general: info: managed-keys-zone: journal file is out of date: removing journal file
08-May-2018 10:24:06.334 general: info: managed-keys-zone: loaded serial 23
08-May-2018 10:24:06.336 general: info: zone 127.in-addr.arpa/IN: loaded serial 1
08-May-2018 10:24:06.339 general: info: zone 10x13.com/IN: loaded serial 1
08-May-2018 10:24:06.340 general: error: /etc/bind/zones/db.11.200.168.192:1: no current owner name
08-May-2018 10:24:06.340 general: error: zone 11.200.168.192.in-addr.arpa/IN: loading from master file /etc/bind/zones/db.11.200.168.192 failed: no owner
08-May-2018 10:24:06.340 general: error: zone 11.200.168.192.in-addr.arpa/IN: not loaded due to errors.
08-May-2018 10:24:06.341 general: info: zone localhost/IN: loaded serial 2
08-May-2018 10:24:06.342 general: error: /etc/bind/zones/db.shadowbanegames.org:3: no current owner name
08-May-2018 10:24:06.342 general: error: zone shadowbanegames.org/IN: loading from master file /etc/bind/zones/db.shadowbanegames.org failed: no owner
08-May-2018 10:24:06.343 general: error: zone shadowbanegames.org/IN: not loaded due to errors.
08-May-2018 10:24:06.419 general: info: zone 0.in-addr.arpa/IN: loaded serial 1
08-May-2018 10:24:06.466 general: info: zone 255.in-addr.arpa/IN: loaded serial 1
08-May-2018 10:24:06.466 general: notice: all zones loaded
08-May-2018 10:24:06.466 general: notice: running
08-May-2018 10:24:06.466 notify: info: zone 10x13.com/IN: sending notifies (serial 1)
08-May-2018 10:24:06.571 queries: info: client 192.168.200.11#48150 (0.ubuntu.pool.ntp.org): query: 0.ubuntu.pool.ntp.org IN A + (192.168.200.11)
08-May-2018 10:24:06.572 queries: info: client 192.168.200.11#48150 (0.ubuntu.pool.ntp.org): query: 0.ubuntu.pool.ntp.org IN AAAA + (192.168.200.11)
08-May-2018 10:24:06.603 queries: info: client 192.168.200.11#48150 (local): query: local IN SOA + (192.168.200.11)
08-May-2018 10:24:06.615 general: info: received control channel command āreconfigā
08-May-2018 10:24:06.615 general: info: loading configuration from ā/etc/bind/named.confā
08-May-2018 10:24:06.615 general: info: reading built-in trusted keys from file ā/etc/bind/bind.keysā
08-May-2018 10:24:06.615 general: info: initializing GeoIP Country (IPv4) (type 1) DB
08-May-2018 10:24:06.615 general: info: GEO-106FREE 20160408 Bu
08-May-2018 10:24:06.615 general: info: initializing GeoIP Country (IPv6) (type 12) DB
08-May-2018 10:24:06.616 general: info: GEO-106FREE 20160408 Bu
08-May-2018 10:24:06.616 general: info: GeoIP City (IPv4) (type 2) DB not available
08-May-2018 10:24:06.616 general: info: GeoIP City (IPv4) (type 6) DB not available
I am sorry for the long post but /i need to get this working as soon as possible.
