It is, all files are copied into one directory though.
Let me make changes so the copy structure looks like this:
to_burn
base
Packages
*.rpm
updates
Packages
*.rpm
and so on.
to_burn
base
Packages
*.rpm
updates
Packages
*.rpm
and so on.
Alright, this is working on my end, @KenPC
import json
import hashlib
import sys
import os
import shutil
from subprocess import call
def loadjson():
try:
with open('/srv/wrapper.json', 'r') as wrapperjson:
fileconfig = json.loads(wrapperjson.read())
except:
print("Error loading file, defaulting to empty")
fileconfig = {}
return fileconfig
def savejson(fileconfig):
try:
with open('/srv/wrapper.json', 'w') as wrapperjson:
wrapperjson.write(json.dumps(fileconfig))
except:
print("error writing file...")
def getcsum(filepath):
with open(filepath,'r') as fileobj:
return hashlib.sha256(fileobj.read()).hexdigest()
def validatejson(fileconfig):
# walks through all the dirs:
for root, subdirs, files in os.walk(repodir):
for item in files:
# Can't use "file" here because it's a reserved name
fpath = root + '/' + item
csumval = getcsum(fpath)
if not fpath in fileconfig:
print("file not in array, ading to list")
fileconfig[fpath] = csumval
elif fileconfig[fpath] == csumval:
print("shasum matched")
else:
return fileconfig
def postcompare(fileconfig):
movelist = []
for item in files:
print("file not in array, adding to list")
movelist.append(fpath)
print("shasum matched, skipping")
else:
print("shasum didn't match, moving to target dir")
return movelist, fileconfig
def movefiles(movelist,destdir, repodir):
if not os.path.exists(destdir):
os.makedirs(destdir)
for fpath in movelist:
relpath = fpath.split(repodir)[1]
destpath = destdir+destpath
print("Copying " + fpath + " To " + destdir)
shutil.copy(fpath, destpath)
def buildreposynccommand(repodir, repos):
com = "reposync"
for item in repos:
com += " -r " + item
com += " -p " +repodir
return com
# Main entrypoint:
if __name__ == "__main__":
print("Starting script")
# Variables here, change me:
destdir = '/root/test'
repodir = '/var/ftp/pub/centos-7-rpms'
repos = ['base','updates']
reposync_command = buildreposynccommand(repodir, repos)
fc = loadjson()
fc = validatejson(fc)
print(reposync_command)
call(reposync_command.split(' '))
movelist, fc = postcompare(fc)
savejson(fc)
Just so weāre clear, the directory structure I have looks like this:
base
Packages
*.rpm
updates
Packages
*.rpm
Alright! Iāll give it a whirl on one I havenāt syncd yet
Hang on, I messed up again.
Alright, try now. Iāve edited the script in the previous post.
got it
Is there a way to add the -d and -n switch to the reposync command?
I added it into here, I hope that works.
com = "reposync"
for item in repos:
com += " -d -n -r " + item
return com
Haha it printed reposync -d -n -r base -d -n -r updates -p /path/to/folder
I guess bash doesnāt care since itās still going
Iām bad at py
If you add another line, just above the for loop, com += " -d -n"
, that should take care of it.
This is how you learn.
so It looks like it worked, but at the end of the script, printed this to stdout
Traceback (most recent call last):
File āpythonscript.pyā, line 94, in
movefiles(movelist,destdir)
TypeError: movefiles() takes exactly 3 arguments (2 given)
Are there issues with python2 and Centos 6.9? It seems to not want to work when I take the same script over to that and run it.
I have all but forgotten that this thread even exists.
Iām having game problems, specifically source games, but not limited to them either.
First up, counter strike source fails to recognize my filesystem, xfs. Fails to load textures because somehow theres too many textures for my 8gb card to handle. And lastly it crashes on render.
Next, tf2, filesystem thing again, hangs at main menu, or crashes X to tty. Thats pretty fuckin stupid.
Next, garrys mod. Canāt load. Doesnāt try.
Next cs 1.6, canāt load, doesnāt try.
Last, csgo randomly hangs for a second, crashes when I die, and freezes at buy menu.
Why is this here? One, filesystem libs, two, I think its an opengl handling problem. I understand I can launch the games in terminal and all that and I have yet to do that. Iām currently forcing myself into ubuntu. What are some things I should check on? Mesa? Are there some libs that are broken by default? All games were fine on antergos but broke when I changed os, though when I went to manjaro to test because I had a disk handy it gave a different just of errors but they are still listed above.
I was told it would probably be a good idea to link this here as well. Iām very tired. Little slow today ^^
Fixed. Steam had fucked libs. Apparently theres package difference between xubuntu and antergos, to the point that it breaks games.
I am a Manjaro user since yesterday and so far I am pretty happy that all went well. There is only one thing that bothers me and that is the question if I want Chrome to be the standard browser every single time I open it. Shouldnāt it be enough to ask that question once? Can I turn it off somehow? When I click links in emails or other non browser apps it opens FireFox instead of Chrome too.
that is controlled by your default app settings, which getting to depends on which desktop environment your running. (gnome, kde, xfce, or so on)
in Gnome you go into settings and the details section is where you can set your defaults. I donāt remember KDEās exact location, and I have never used xfce, but most desktops have settings menus that will have what you are looking for.
Just a heads up, I had problems with the script I really appreciate your time. but after much digging and practicing my Google-Fu, I came across an obscure Github with a python program called PakRat that does EXACTLY what I wanted. It even can download the latest packages and put them into a folder tree with the date appended to the folder name in which it was downloaded. Pretty cool shit. Even provides a progress meter.
I did that but Chrome is still asking everytime I open the browser
sorry, I miss read your post. to stop chrome from asking, that should be in chromeās settings, under the default browser section, should be a slider to stop if from asking you. probably named something like ācheck default browserā or ācheck at startupā
Yeah, Iām a shitty programmer.
Glad you were able to find a solution!
solved my issue, wierdly arch had update that solved the issue.
originally I had reinstalled antergos with the LTS version to see if that would help. Reinstalling the system solved my bluetooth issues, but not the shutdown errors.
the issue resolved itself in a update(kinda like my scroll wheel
I need some pointers on virtual networking in virt-manager / qemu. No matter how much I read about it I just canāt get the VM on the same network as the host (and everything else).
The goal (for the VM) is to mount an NFS share, be accessible from other systems on the internal network, and also have internet access. Through some bastardization voodoo I was able to get it to mount the NFS share, but it didnāt have internet access and I probably couldnāt access it from another system.
Any suggestions?
