I had an unclean reboot of Ubuntu 22.04. I read that I should hit my SSD with fsck, but to make sure it isn’t mounted. I rebooted with a live CD, dropped to a terminal, and ran fsck /dev/nvme0n1p1 (which is my root drive) and it said it can’t run because it isn’t mounted. I mounted it (cautiously) and reran fsck which then warned me it would screw the partition up. So then I unmounted it again and re-ran fsck, which again refused to run because it wasn’t mounted. What am I missing here?
I just tested this on my /boot partition (bravo, not romeo) and it seemed to work as expected. I was only able to fsck when it wasn’t mounted. I wonder if the filesystem is corrupted and it is reported bad information. Also, what filesystem do you have on your root drive?
# fsck -fv /dev/nvme0n1p2
fsck from util-linux 2.36.1
e2fsck 1.46.5 (30-Dec-2021)
/dev/nvme0n1p2 is mounted.
e2fsck: Cannot continue, aborting.
# umount -l /boot/
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
349 inodes used (1.07%, out of 32768)
3 non-contiguous files (0.9%)
1 non-contiguous directory (0.3%)
# of inodes with ind/dind/tind blocks: 0/0/0
Extent depth histogram: 341
65278 blocks used (49.80%, out of 131072)
0 bad blocks
1 large file
333 regular files
7 directories
0 character device files
0 block device files
0 fifos
0 links
0 symbolic links (0 fast symbolic links)
0 sockets
340 files
# mount /boot/
Give up on Pulse and take the plunge to Pipewire. It is well worth the effort and is very likely to work out of box.
I know this sounds like the old “Install Linux and all your Windows-related problems will just vanish!” snake oil some people used, but in this case there really is no reason to cling to pulse. Just let go already.
Oh? I had no idea about pulse vs pipe. pulse was default install. Will investigate, thanks.
Still learning Linux coming from a decade+ of windows. My main tower daily driver is linux, but I keep a separate and dedicated machine for each of window, mac, and linux and pick the right tool for the job depending what I’m working on. For example ableton runs like butter on the mac, and not at all on linux. I haven’t tried ableton thru wine yet.
I don’t really care about the platform anymore as long as I can do my work and the OS and software doesn’t get in my way.
Do you have a way to boot from an Ubuntu install disk using the same version? You can do the Try Ubuntu option and at least get to a working environment from which to troubleshoot from.
Can anyone determine why simply starting docker.service on the hypervisor (e.g. systemctl start docker.service) disables all access to trueNAS (web portal, ssh, ping)?
VNC’ing into the trueNAS instance shows the typical incorrectly configured interfaces prompt:
The web user interface is at:
http://0.0.0.0
https://0.0.0.0
I have a backup of some files and when I need to restore some I’ll do a find command and then copy paste the location and use rclone to copy it back to where I need it.
When I want to restore several files I can sometimes get away with using “*” so I’ll get a few of them in one transfer.
Is there a nice CLI way for me to do a find or multiple find commands (or similar) and then multi select which files I then want to pass into my rclone command?
It’s a small linux problem because manually copy pasting each result I need works fine.
If I’m going to solve it myself I would use something like this
