I just noticed this page: Zabbix install from sources
What is the difference between this and using the SRPMs mentioned above? Would this maybe ork better for me?
Is anyone else having issues where you get stuck the activities menu if you open activities in gnome?
https://bbs.archlinux.org/viewtopic.php?id=257235
Itās apparently an issue, but not with gnome, rather itās an issue with dash to panel
looking at the github issues page, it has been reported
Looking at the referenced issue
The Dash to Panel devs seemed have the issue fixed in the master version, but it doesnāt appear to be pushed to the version on the gnome shell extensions page
To solve the issue, I have temporarily disabled the activities menu. As an alternative, I am currently using arcmenu to search and launch applications.
https://extensions.gnome.org/extension/1228/arc-menu/
I have also have the no top left corner extension to prevent accidental activities activation
https://extensions.gnome.org/extension/118/no-topleft-hot-corner/
I recently had issues upgrading docker from fedora 31 to fedora 32
This guide was helpful in installing docker on fedora 32
I had previously used the guide by docker, but I think it didnāt translate well
I had issues when running the dnf upgrade
command since the docker had an older repo I had added on fedora 31
sudo dnf upgrade (base)
Docker CE Stable - x86_64 1.7 kB/s | 384 B 00:00
Errors during downloading metadata for repository 'docker-ce-stable':
- Status code: 404 for https://download.docker.com/linux/fedora/32/x86_64/stable/repodata/repomd.xml
Error: Failed to download metadata for repo 'docker-ce-stable': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
Ignoring repositories: docker-ce-stable
Last metadata expiration check: 0:22:04 ago on Sun 16 Aug 2020 11:36:32 AM CDT.
Dependencies resolved.
Nothing to do.
Complete!
to get rid of the docker-ce-stable
repo, I followed the dnf disable commands from the fedora dnf guide
https://docs.fedoraproject.org/en-US/Fedora/23/html/System_Administrators_Guide/sec-Managing_DNF_Repositories.html
which looked like this
dnf config-manager --set-disabled docker-ce-stable
now when I run the dnf upgrade
command, my shell outputs the following
Last metadata expiration check: 0:24:58 ago on Sun 16 Aug 2020 11:36:32 AM CDT.
Nothing to do.
Complete!
Yep
What do you Mean I should Read the Fabulous manualā¦
Well, I just realized that not everyone has gpg keys set up. Iāve been using it for so long and since all my coworkers use em, I just sorta assume itās commonplace. Sorry!
But yes, man gpg is great.
I genuinely thought the new GnuGPG might have a central place, like a github section, or some central pace, mostly because the command didnāt pass a key file.
Compiling and installing a program from source doesnāt put it in your RPM database, which means you donāt have a listing of where/what files were installed, and you canāt do nice stuff like verify the checksums of the installed files. If other RPMs depend on it, they will think itās not installed and refuse to install. etc. You can certainly try it, itās possible your problems are only with rpmbuild and you might get past that.
So GPG works kinda like a package manager, in that you can receive keys from a keyserver. Basically download someone elseās public key. But thereās no hardcoded master server.
For example, thereās http://keys.gnupg.net
Okay, cool, so I was simply wrong, not outrageously crazy? Iāll take it!
Itās not that they donāt have a central repository. Itās just that itās not really designed to be tightly integrated.
So itās cleaner to go ahead with the SRPM compile with rpmbuild?
I will post progress soon.
Open-ended Poll:
What is the best terminal emulator in Wayland (preferably not relying on xwayland), and why?
alacritty?
Because itās not Gnome Terminal and has native wayland support
Terminator.
Itās awesome. Has working transparency and split panes. 25666 colors
- Terminology
- Terminology
- Terminology
- Terminology
- Terminology
- Terminology
- Terminology
0 voters
Because:
- In-terminal video, picture and thumbnail support
- Looks smashing
- Very fast
- Scalable fonts
- Integrates with Enlightenment WM
- Amazing Cotext Menu (RMB)
0 voters
Excuse me, but an open poll should be like this?
Will try Terminology and alacrity, thanks all!
New question for today:
How do people deal with tmux > ssh > tmux nesting? Do you just change the prefix hotkey locally and use C-b for the remote session? Afaics thereās no way to directly attach a remote session, right?
Ideally, Iād have a local session that connects to the remote socket and it would load my own tmux.conf. No double status bars and that sort of thingā¦
on your local machine remap the command key. I use ctrl a instead of ctrl b
or⦠ya know⦠donāt use tmux on your local machine for regular ops.
Yeah that seems like the way to go. I just wish I could have it load my local .tmux.conf but I guess there are compatibility issues and other potential issues with that.
What if one used screen within tmux? Or would they conflict? #honestQuestion
Or like Tmux local, screen on remote
