Oh sorry, pacman, manjaro technically (netrunner rolling). Normal manjaro didn't have the right driver for my mouse, netrunner is always my fallback. Everything works great except updates....
pacman -R qtchooser
run this first
pacman -R qt4-gstreamer
then this command.
pacman -R xf86-input-aiptek
and finally this command
I get that stuff needs to be removed but is there a reason this all gets locked up?
done a sudo pacman -Syy ?
-Syyu but yes
As far as I can see, xf86-input-aiptek is the Aiptek USB Digital Tablet Input Driver for Linux, and this guy ben81 says it is obsolete now (answering to literally the same conflict you have), but I wonder, does xorg-server have build in drivers for USB devices? I only have a vague idea of what different packages do, but maybe you more linux-enlightened people knows.
the problem was the aiptekdriver. That rando @-@
So, I have some experience with writing code (using R, in case you were wondering), but I am unsatisfied with it for a few reasons, so i figured teaching myself C++ would be a good place to start with. the problem I'm having is that, libraries and interfacing with display apis, were covered by the language and ide i was using respectively, so I don't really know how to do either of those things.
I figured the bit about libraries would be fairly simple, all you have to do is:
#include whatever library
and you're set to go, right?
Apparently not.
I'm trying to use xcb on my fresh install of fedora 25, but the pre-processor can't seem to find it.
I'm probably missing something super obvious, but I really can't figure this out. Thank you in advance.
maybe the library is missing on your computer ? I am not a programmer but after a quick google search that was the most common answer. If it is not present you will have to download it.
Its gonna be probably -
yum install whatever library
xcb should be used by a lot of things, and I did try to install it, so i do know that it's there.
Just jumping in with a guess,
Try "whereis libX11-xcb.so.1" in a terminal.
Should return something like "/usr/lib/libX11-xcb.so.1" or "/usr/lib/libX11-xcb.so.1.0.0"
Then see if you can work out where your ide is trying to find the file. might be looking in the wrong place?
Does anyone know how/what I would need to get the dedicated scroll button on Lenovo Thinkpads to work on Arch?
I tried using gpointing-device-settings, but I am not sure about setting up the dedicated scroll button.
Am i missing some drivers?
I did that, it returned /usr/lib/libX11... and /usr/lib64/libX11...
So, how do i tell the pre-processor to look there when i want to include that library?
New issue.
:: Replace telepathy-qt5 with extra/telepathy-qt? [Y/n]
resolving dependencies...
looking for conflicting packages...
:: qt5-base and qtchooser are in conflict. Remove qtchooser? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
[ph4nt0m@dark0rbit ~]$ sudo pacmas -R qtchooser
sudo: pacmas: command not found
[ph4nt0m@dark0rbit ~]$ sudo pacman -R qtchooser
checking dependencies...
error: failed to prepare transaction (could not satisfy dependencies)
:: qt5-base: removing qtchooser breaks dependency 'qtchooser'
If I delete that random driver I get dumped out here and I can't do anything there isn't even a force option.
Here's stuff I found, try some of these.
not sure if this can help, but looks like some one has a similar problem with trying to remove qtchooser
https://bbs.archlinux.org/viewtopic.php?id=217836
https://bbs.archlinux.org/viewtopic.php?id=217852
this link looks like someone found a way to fix the issue
sudo pacman -S qt5-base
yaourt -Syua
but the way the fixed it was to use yaourt
Ok it looks like the yaourt fix has done it. I might actually use yaourt instead as it is buildng around the broken holes and patching them as they go.
downloading required keys...
:: Import PGP key 2048R/22C903DE964E6FE321656E318DB9F8C18DF53602, "Stefano Capitani <[email protected]>", created: 2016-02-28? [Y/n] y
error: key "Stefano Capitani <[email protected]>" could not be imported
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
Errors occurred, no packages were upgraded.
New isue. I have never had this issue before so I don't really know what to do.
bump
Might try something like this: https://bbs.archlinux.org/viewtopic.php?id=198132
Keyring may be outdated or corrupted.
I don't Arch, so I am not all that familiar with the OS.
I tried installing TeamSpeak 3 in Ubuntu lately, and I've been having a little problem lately. I downloaded the 64bit archived package and then did thissudo chmod u+x ./ts3package.run
./ts3package.run
It got me to the terms of service thing, which I agreed to and it unpackaged the files. Then 3 sources from the Ubuntu forums told me to open the ts3installer, but whenever I click on it, it does practically nothing. I also tried dragging the file into bash, but it told me that it couldn't find the file or directory.
Google told me nothing (hopefully, so I don't sound like an idiot).
I am running Ubuntu 64bit on an LVM Disk, if that matters.
Did I do something wrong or is something wrong with my system? This carried over from 2 Ubuntu installations.
