After updating if there’s changes in the kernel the proprietary drivers may break, you know it’s caused by a kernel change if everything works fine when you boot to your previous kernel from grub.
If that’s the case, uninstall the drivers - boot to your newest kernel and reinstall the drivers.
Turns out that rebalancing BTRFS requires quite a bit of CPU. If you have an unclean shutdown and the machine tries to rebalance upon start up with a single CPU it can hang.
Moral of the story. Don’t use a single processor on BTRFS.
Having some problems with pulseaudio. I’m using a proaudio card which needs some changes in default.pa and asound.conf otherwise i only get mono output. Mainly to do with detection, here is what i changed in default.pa load-module module-alsa-sink device=hw:0,0 tsched=0
Commented out this:
### Automatically load driver modules depending on the hardware available
#.ifexists module-udev-detect.so
#load-module module-udev-detect tsched=0
#.else
### Use the static hardware detection module (for systems that lack udev support)
#load-module module-detect
#.endif
And asound.conf:
pcm.!default {
type hw
card 0
ctl.!default {
type hw
card 0
There are some other changes but they have to do with resampling quality and such.
Anyway every time i login pulse mutes the pcm 0 channel in alsamixer, if i check before login into the DE from another tty it is unmuted.
Using Fedora 30 beta with Kde. On other distro’s i did not have this problem but i was not using the config files in the home folder then, sometimes they got changed so i switched to this when i installed F30. I basically copied over the config files to ~ and edited to my needs, permissions seem to be fine as well.
