Distro: Fedora 29
System: HP Zbook 15 G3
Video Adapter: nVidia Quadro M2000M
Video Driver: nVidia Proprietary 410.93
I am seeing small ‘hitches’ every now and then in both games and video playback, such as plex and youtube. Otherwise, everything runs fine. I could probably stand it if it happened only in games, but I can’t even watch a movie without getting super annoyed.
This is on a near fresh install (I have made some modifications to the UI such as Dash to Dock and a few other tweaks) with the noveau driver blacklisted and the proprietary driver straight from nVidia installed. I am assuming the issue is in the driver somewhere, or possibly Wayland but am unsure how to fix it. Just looking for some advice/experience.
Have you tried choosing Gnome on Xorg before you log in? Nvidia and wayland is not a good idea. I think Wayland is even disabled when you install Nvidia from rpmfusion, did you specifically enable it?
I had not tried that. I turned off all of the gnome extensions that I installed and only enabled the ones I found absolutely necessary and it worked itself out, though. I’ll see if I can figure out which one it was this weekend.
I think you misunderstand, when you log in and can type your password there is a small cog you can click. There you have a menu with things like Gnome and maybe others, if you see one with Gnome on Xorg and it is not the default try that. If you don’t have that chances are you’re probably already running on Xorg. In that case have a lookt at https://wiki.archlinux.org/index.php/NVIDIA/Troubleshooting
Yes. Networking works, aside from my intermittent connection issue. I was wondering if that message is indicative of a problem, and also if it might be related to my issue.
Not sure if it’s related but I consistently get this error in dnfdragora when trying to access one specific transaction history on the day that I upgraded to Fedora 29.
