The right case for these parts?
i don't know if this is the right place to post this but i'm building my first gaming rig. and i'm wandering with my list of parts what would be the best LAN cube case i should get. can i get some help with this?
Motherboard
MSI 970 GAMING ATX AM3+ Motherboard
CPU
AMD FX-8350 4.0GHz 8-Core Processor
Heat sync
CRYORIG H7 49.0 CFM CPU Cooler
GPU Card
MSI Radeon R9 390 8GB Video Card
Power Supply
Cooler Master VSM 750W 80+ Gold Certified Semi-Modular ATX Power Supply.
if this is the wrong place to post it would be appreciated to know where to go. thanks
Not much of a LAN rig, since it will be an ATX build with massive GPU and massive CPU cooler... LAN rigs tend to be mini-IT or micro-ATX.
If you want a case though, an H440 from NZXT would be fine, or for more budget minded, a N400 would do fine.
This is what I'd consider a LAN rig, or something slightly larger. An ATX build is hard to carry around and find space for.
https://forum.teksyndicate.com/t/new-build-based-on-the-pentium-g3258-that-fits-in-a-backpack/84031
I would consider this:
http://pcpartpicker.com/p/q9x4TW
wow that is a nice case. so that motherboard i got will fit in that thing? i'm still new at this but the atx mother board is able to fit in a micro atx case?
Oh.... I thought you didn't have the rig, but rather that was a schematic.
I would recommend a Cooler Master Haf XB Rev 2 then.
