The PC Fans Keep Spinning
I encountered a strange problem: My Windows computer shut down normally - the screen turned black and all devices seemed to lose power - but the fan inside the case kept running at full speed until I unplugged the power cord from the wall or turned off the power supply. This situation occurred every time I shut down the computer.
Some motherboards do so for a minute or so after shutdown to ensure hardware does not overheat in the interval where there is still heat radiation but no airflow.
Another weird possible cause is that sometimes the TV or monitor -when connected using HDMI- can inject power into the motherboard.
Try shutting down normally, then unplug the TV/monitor cable and check if the fan stops.
You need to try disabling Fast Startup.
You can start by disabling Fast Startup in the Power Options section of the Control Panel. If that doesn’t solve the problem, try entering the BIOS and disabling ErP or Deep Sleep.
Hi, guy. This usually indicates that your system is not completely powered off.
Have you already found a solution?
I have had this issue with my old Laptop after i tried booting Ubuntu on it, then i found someone in a german forum with the same Problem but on a PC. The hardware seemed to not turn off and the CPU still got hot too even though the screen went black and i always had to turn it off with the power button.
The only solution was to clear the CMOS, so either with a jumper if your PC has one or remove the BIOS/CMOS Battery entirely for a few minutes while the PC is unplugged. Then it went back to normal again.
