So, this thread is similar to the small linux problem thread. I am making it because I recently got a 3-D printer and do not know everything there is to know. If you are going to post a problem I suggest you mention the printer.
I currently have a Pursa i3 mk 2. In the process of calibration, this started happening.
https://www.youtube.com/watch?v=tU75zdX5NpU
Sounds like gears grinding for some reason. Any help is appreciated.
did you post youtube link?
I'm not seeing anything...
I did, let me try to fix it.
I think the expanded link display for youtube links is one of the many things that got borked by the move.
You can just use [url] tags
AH, got it. I have some ideas.
1 wire is disconnected on the motor in question. Stepper motors rattle back and forth like that when only 1 coil is getting engaged.
It only does that in that part of the axis.
oh... in that case check that the teeth on the belt are ok.
I dont see anything wrong with any of the teeth.
Check all of that belt for any grit that may jam it in that spot.
Can you take a vid closer to motor and from the other side?
I'm wondering if it's the motor spazzing or the belt/mechanism failing.
Unless there's something physically blocking it from moving (and thus stalling the motor), the motor is behaving exactly like only one coil is being powered.
This could be from a number of different things:
- Faulty motor driver (the circuit board)
- poor wire connection
- check plugs are seated fully
- use continuity checker (multimeter) and move wires around to find if there's a break inside the wire. (very unlikely but is a possible solution)
- check where wires go into motor housing... any sign of damage? They could be lose inside housing.
I have started looking, dont have the multimeter with me so I cant do that, I do remember this not being an issue when I first put the printer together.
I dont see any look connections or damage.
So it turns out the printer only does that when auto calibrating the bed. I cannot get it to do that any other time. At all. Period.
I know. Im trying to re calibrate the axi and see if that does anything. I might have actually found the problem. Two zip ties that werent cut short enough. I've done it before on this printer.
Where they blocking something?
The first ones were making two screws not go all the way down making the bed unlevel
Looks like it magically fixed itself.
