I’d be up for pre-orders.
Cheers.
Cheers.
I would also like to pre-order. Thanks!
Any update on the firmware? This damn 580 is still causing problems, apparently.
[14416.826574] [drm:amdgpu_atombios_dp_link_train [amdgpu]] *ERROR* displayport link status failed
[14416.826619] [drm:amdgpu_atombios_dp_link_train [amdgpu]] *ERROR* clock recovery failed
[14417.006517] [drm:amdgpu_atombios_dp_link_train [amdgpu]] *ERROR* displayport link status failed
[14417.006564] [drm:amdgpu_atombios_dp_link_train [amdgpu]] *ERROR* clock recovery failed
[14417.212912] [drm:amdgpu_atombios_dp_link_train [amdgpu]] *ERROR* displayport link status failed
[14417.212962] [drm:amdgpu_atombios_dp_link_train [amdgpu]] *ERROR* clock recovery failed
[14417.392861] [drm:amdgpu_atombios_dp_link_train [amdgpu]] *ERROR* displayport link status failed
[14417.392908] [drm:amdgpu_atombios_dp_link_train [amdgpu]] *ERROR* clock recovery failed
This is noise on the DP line. This is going to sound weird, but can you put the metal case of the KVM in contact with the metal case of your computer? wondering if it is a grounding issue maybe. using the l1 cables for the 580?
Using all L1 cables. They arrived last week. Thanks babe!
I’ve actually got the kvm resting on top of my case (Meshify C), I can drill in a grounding strap/cable if you think it’s worth going all the way.
which 580 is it? using an asus 580 it seems flawless. Is this on bare metal or vm?
Bare metal and MSI 580. (linux)
Also game for pre-order.
This KVM is something I’ve been looking for a while! I have a gaming desktop, and work laptop, and I switch back and forth between the two fairly frequently, and it’s usually a multi-minute process everytime to get all the USB devices + inputs switched. Also, my current KVM-less setup requires that I use HDMI for the laptop, and completely lose high refresh rate.
Quick question: I have two monitors, one is 3440x1440 100 hz, and one is 1920x1080 144hz. The ultrawide seems like it’ll be very near the bandwidth limit, has anyone had any experience with this?
I’d be up for a pre-order!
The widescreen will be very near the bandwidth limit. Based on customer service support inquiries for sure keep the total dp length at 4m or under
I’m also interested in pre-order.
I’m planning to mount everything close together, so 4m won’t be a problem.
As has been noted before, I have found that finding a good DP cable can be a pain, so I was planning on just ordering the wire kit together with the KVM once these are available. What is the length of these cables (< or > 4m?). Thanks!
L1 dp cables are around 1.99m
I am also running into issues on my WX5100 when attempting to use 2 monitors with the KVM.
Using these cables:
Can you take video? Anything on the event log about edid link failures?
I will gather some info for you. Should I post it here?
Sure or dm.
If you post it here, I can confirm if it’s the same or a similar issue I’m having.
Brief background on my issue.
I was using the dual-kvm with a single monitor. The screen would occasionally go black for a second and come back on. I recently took everything apart and put it back together (computer and cabling). Was experimenting with 2 monitors. The computer would black out as before but would not come back until reboot (via SSH). Went back to single monitor and no improvement over 2 monitors (so worse than before somehow).
Brief system spec: Supermicro X11SSL-F, Xeon E3-1230 v6, Radeon WX5100, LG 43UD79-B, Solus (up to date)
The issue has not yet happened on my Macbook Air, but I use it sparingly and it can take hours for the issue to appear.
It’s definitely running along the monitor’s power cable. I can see if it’s hitting anything else in the cable management when I get home… It is on a sit/stand desk, so it is probably running by the motor…
Here is sudo journalctl -b
via SSH after the display loses the signal. Nothing stands out to me, but this sort of issue is not within my area of expertise. Is there a utility I can use to monitor the status of the DP handshake/signal status?
Apr 05 01:41:52 REDACTED budgie-wm.desktop[1192]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x2200008 (Authentica)
Apr 05 01:41:54 REDACTED psensor.desktop[1338]: [2018-04-05T05:41:54] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:41:56 REDACTED psensor.desktop[1338]: [2018-04-05T05:41:56] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:41:57 REDACTED polkitd[845]: Operator of unix-session:c2 successfully authenticated as unix-user:REDACTED to gain ONE-SHOT authorization for action org.gsmartcontrol for unix-process:14714:9830799 [bash /usr/bin/gsmartcontrol-root] (owned by unix-user:REDACTED)
Apr 05 01:41:57 REDACTED pkexec[14718]: pam_unix(polkit-1:session): session opened for user root by (uid=1000)
Apr 05 01:41:57 REDACTED pkexec[14718]: pam_systemd(polkit-1:session): Cannot create session: Already running in a session
Apr 05 01:41:57 REDACTED pkexec[14718]: REDACTED: Executing command [USER=root] [TTY=unknown] [CWD=/home/REDACTED] [COMMAND=/usr/sbin/gsmartcontrol]
Apr 05 01:41:58 REDACTED org.a11y.Bus[14731]: Activating service name='org.a11y.atspi.Registry'
Apr 05 01:41:58 REDACTED org.a11y.Bus[14731]: Successfully activated service 'org.a11y.atspi.Registry'
Apr 05 01:41:58 REDACTED org.a11y.atspi.Registry[14745]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Apr 05 01:41:58 REDACTED psensor.desktop[1338]: [2018-04-05T05:41:58] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:41:58 REDACTED budgie-panel.desktop[1206]: <warn> [hz] Warning: exit: Command line did not parse.
Apr 05 01:41:58 REDACTED budgie-panel.desktop[1206]: <warn> [app] execute_smartctl(): Smartctl binary did not execute cleanly.
Apr 05 01:41:58 REDACTED budgie-panel.desktop[1206]: <warn> [app] StorageDevice::execute_device_smartctl(): Smartctl binary did not execute cleanly.
Apr 05 01:41:58 REDACTED budgie-panel.desktop[1206]: <warn> [app] SmartctlParser::parse_section_info_property(): Unknown property "Temperature Warning"
Apr 05 01:41:58 REDACTED budgie-panel.desktop[1206]: <warn> [app] SmartctlParser::parse_section_data(): Unknown Data subsection encountered.
Apr 05 01:41:58 REDACTED budgie-panel.desktop[1206]: <warn> [hz] FS warning: Error while opening file "/proc/scsi/sg/devices": No such file or directory.
Apr 05 01:41:58 REDACTED budgie-panel.desktop[1206]: <warn> [app] {anonymous}::read_proc_scsi_sg_devices_file(): Sg devices file doesn't exist.
Apr 05 01:42:00 REDACTED psensor.desktop[1338]: [2018-04-05T05:42:00] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:42:02 REDACTED psensor.desktop[1338]: [2018-04-05T05:42:02] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:42:04 REDACTED psensor.desktop[1338]: [2018-04-05T05:42:04] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:42:04 REDACTED budgie-panel[1206]: IconTasklistApplet.vala:418: Invalid application! hexchat.desktop
Apr 05 01:42:04 REDACTED budgie-panel[1206]: IconTasklistApplet.vala:418: Invalid application! vlc.desktop
Apr 05 01:42:06 REDACTED psensor.desktop[1338]: [2018-04-05T05:42:06] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:42:08 REDACTED psensor.desktop[1338]: [2018-04-05T05:42:08] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:42:09 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:42:10 REDACTED psensor.desktop[1338]: [2018-04-05T05:42:10] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:42:12 REDACTED psensor.desktop[1338]: [2018-04-05T05:42:12] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:42:14 REDACTED psensor.desktop[1338]: [2018-04-05T05:42:14] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:42:16 REDACTED psensor.desktop[1338]: [2018-04-05T05:42:16] [ERR] lmsensor: Cannot get value of subfeature fan1_input: Can't read.
Apr 05 01:43:06 REDACTED kernel: [drm] HBR2x4 pass VS=3, PE=0
Apr 05 01:43:06 REDACTED kernel: usb 1-12.4: USB disconnect, device number 8
Apr 05 01:43:06 REDACTED upowerd[939]: unhandled action 'unbind' on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12.4/1-12.4:1.0
Apr 05 01:43:06 REDACTED kernel: usb 2-1.4: USB disconnect, device number 3
Apr 05 01:43:06 REDACTED upowerd[939]: unhandled action 'unbind' on /sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1.4/2-1.4:1.0
Apr 05 01:43:07 REDACTED audit[12480]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12480 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:43:41 REDACTED kernel: usb 2-1.4: new SuperSpeed USB device number 4 using xhci_hcd
Apr 05 01:43:41 REDACTED kernel: usb 2-1.4: New USB device found, idVendor=2109, idProduct=8110
Apr 05 01:43:41 REDACTED kernel: usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Apr 05 01:43:41 REDACTED kernel: usb 2-1.4: Product: USB3.0 Hub
Apr 05 01:43:41 REDACTED kernel: usb 2-1.4: Manufacturer: VIA Labs, Inc.
Apr 05 01:43:41 REDACTED kernel: hub 2-1.4:1.0: USB hub found
Apr 05 01:43:41 REDACTED kernel: hub 2-1.4:1.0: 4 ports detected
Apr 05 01:43:41 REDACTED upowerd[939]: unhandled action 'bind' on /sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1.4/2-1.4:1.0
Apr 05 01:43:41 REDACTED kernel: usb 1-12.4: new high-speed USB device number 15 using xhci_hcd
Apr 05 01:43:41 REDACTED kernel: usb 1-12.4: New USB device found, idVendor=2109, idProduct=2811
Apr 05 01:43:41 REDACTED kernel: usb 1-12.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Apr 05 01:43:41 REDACTED kernel: usb 1-12.4: Product: USB2.0 Hub
Apr 05 01:43:41 REDACTED kernel: usb 1-12.4: Manufacturer: VIA Labs, Inc.
Apr 05 01:43:41 REDACTED kernel: hub 1-12.4:1.0: USB hub found
Apr 05 01:43:41 REDACTED kernel: hub 1-12.4:1.0: 4 ports detected
Apr 05 01:43:41 REDACTED upowerd[939]: unhandled action 'bind' on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12.4/1-12.4:1.0
Apr 05 01:43:42 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:43:55 REDACTED kernel: usb 1-12.4: USB disconnect, device number 15
Apr 05 01:43:55 REDACTED upowerd[939]: unhandled action 'unbind' on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12.4/1-12.4:1.0
Apr 05 01:43:55 REDACTED kernel: usb 2-1.4: USB disconnect, device number 4
Apr 05 01:43:55 REDACTED upowerd[939]: unhandled action 'unbind' on /sys/devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1.4/2-1.4:1.0
Apr 05 01:46:23 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:46:47 REDACTED audit[1802]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=1802 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:47:07 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:49:00 REDACTED audit[12480]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12480 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:49:15 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:50:00 REDACTED audit[12480]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12480 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:50:50 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:53:07 REDACTED audit[12480]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12480 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:55:35 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:56:09 REDACTED audit[1802]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=1802 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 01:57:03 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 02:00:11 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 02:00:56 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 02:03:07 REDACTED audit[12480]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12480 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 02:03:07 REDACTED audit[12517]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12517 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 02:04:06 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 02:04:36 REDACTED audit[12303]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=12303 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
Apr 05 02:04:50 REDACTED audit[1802]: SECCOMP auid=4294967295 uid=1000 gid=1000 ses=4294967295 pid=1802 comm="chrome" exe="/opt/google/chrome/chrome" sig=0 arch=c000003e syscall=273 compat=0 ip=0x7f9fe3c4c609 code=0x50000
By the motor. I’d definitely check that.
The monitor’s power cable is probably not an issue in itself though. I don’t think it would be creating enough of a field to induce interference.
