Thats why he made them in the first place. Because he couldnt find any that were even semi-decent
Bought the dual display port version for use with my work laptop and home desktop. Now that I finally have a new desktop with multiple display ports, I hooked up using my microsoft wireless keyboard/mouse (model 5000). I saw the notes about wireless not working so was absolutely geeked when it worked flawlessly for a couple of days. Now, my desktop seems to be fighting the connection and frequently drops/reconnects. Laptop works flawlessly. Just wondering if there are any wireless keyboard/mouse that work better. Thanks!
try the usb3 ports instead of the usb2 ports, and when switching, try doubletapping numlock.
tbh the only device that was super problematic was OLD usb wireless recievers by logitech. When sending them a reset command they will not actually reset unless you kill powerā¦ which I canāt do because it causes more problems with other devices than it solves. also dramatically increases input switching time.
usb3 ports should mostly leave the reciever alone. its the keyboard that cuts out not the display right?
I bit the bullet and bought a nice 4-port Dual Link DVI KVM some years ago. Been shopping for a new monitor lately and sadly, DVI has gone the way of the brontosaurus, because of the limited bandwidth. OMG, when I started pricing Display Port KVMs, I found that I could buy a nice 21:9 1440P monitor for the cost of a decent Display Port / USB 3.0 KVM! Holy excrement Batman!!!
And whatās the deal with new monitors only having a single DP input? WTF??? I guess Iāll have to figure out how Looking Glass works ā¦
Mine keeps beeping at me in random bursts, think its trying to tell me something
@wendell do you have a waiting list for the next batch of KVM switches that I could sign up to please?
Hi All,
I need some cash for the holidays so I am selling my Dual Monitor KVM.
Feel free to put an offer in here:
Back in stock yāall
Two dp cables plus two USB cables is 4 cables, cables kit is optional, though
NOTE: No cables are included, but we are selling a separate 2 pack of 19 pin DisplayPort 1.2 (4k/60hz certified) + USB3 (5gbps) cables separately here.
ref:
The very first batch of KVMs few people wanted to pay extra for cables they didnt want, so the cable kit is optional now. 4 cables in the kit, two dp, two usb:
So if you want 4 dp + 4 usb3 just get two cable kits
3,5mm audio should be ok
and its the us style plug. but I think the transformer supports 230 so just a mechanical adapter should be all you need?
I HIGHLY recommend the cable kit. Iāve had display issues with any cables that arenāt the ones from the kit. I went so far as to buy a total of 10 from Wendell lol
They are a good deal. No profits made on cable kits lol
Thats a shame. Should have a for profit and a non profit kits XD
Any word on possibly a DisplayPort 1.4 model? Been eyeing the new LG 34" 5K2K HDR DCI-P3 ultrawide, but itās DP 1.4 (in theory would work in non hdr mode, as itād be under 17 Gb, but HDR mode would be 19 Gb.)
hi
any body hellp me
i have a manual kvm 4port and display not worked
when satart pc i have display on bios,but when windows(win7) started display go off !!
hellp mee pleasss
@wendell I just received the dual display KVM, and Iām aiming to use it with a Windows PC with a 1080 Ti and a 2018 Mac Mini. My monitors are a Dell S2716DG and an Acer XB270HU, both of which are 1440p/144hz gsync capable monitors. On the Windows machine, both of these monitors are working fine for the most part, although I have noticed some flickering with gsync occasionally, and sometimes after switching back, the Acer is detected with a max refresh rate of 85hz instead of 144hz. The real issue Iām running into here is that only the Dell display is detected by the Mac Mini. By switching ports and cables around, I did very briefly get it to see the Acer, but I havenāt been able to replicate that since. Connecting the monitors directly to the Mac works just fine.
Iāve tried using the cables directly from you guys, as well as these and these. For the regular DisplayPort cables, Iāve been trying with this DisplayPort to Thunderbolt 3 converter. I get exactly the same results with every combination.
Iām not sure what else to try.
The only known good cables are the ones in the kit. I believe Wendell will sell you some, but I donāt want to put words in his mouth.
Your problem is almost certainly a display port 1.2 issue but itās also possibly the cables. Iāve had issues with display port protocols over 1.2.
Ah, it could also be the thunderbolt adapter causing trouble.
I mentioned in my post that I tried the cables from here. I ordered two sets. I get the same results with them as with the other cables I have. And everythingās working fine on Windows, as noted.
I do have an update, thoughā¦ I swapped the cables between the ātopā and ābottomā ports on the KVM (I had previously only been switching to different numbered ports, but not changing which monitor went into the top and which went into the bottom), and now I have the reverse behavior. The Acer is detected, but the Dell isnāt.
It could be the Thunderbolt adapter, but the standalone DisplayPort -> Thunderbolt cables I have exhibit exactly the same issues.
What do you mean by DisplayPort 1.2 issue?
Sorry, Iām not 100% right now, I did notice that youād tried them though.
This kvm technically doesnāt support over 1.2. After manually switching my monitors to disable 1.2a, in favor of 1.2, it worked fine. At least, thatās my experience.
In regards to the thunderbolt adapter, it is possible. I donāt really know what to say there, since I donāt actually have hardware to test it with. Itās possible, and we have seen problems with them before.
