The Gamers Nexus Anniversary Edition Mug Review
Introduction
The Anniversary Edition Mug is a midrange ceramic mug sold by the Youtube channel Gamers Nexus. Because Anniversary Edition Mug and Gamers Nexus is a mouthful to say, for the rest of the review, we will be referring to Gamers Nexus as GN and the mug as the AE Mug.
Wendell the distributor, did a great job packing the mug, using a combination of bubble wrap and packing paper. The mug was shipped with DHS in a box twice the size of the mug with 2 fragile stickers on the top and bottom of the package.
Mug specs
The AE Mug is reported, by the store listing, to hold 15 ounces or 444 milliliters. The AE Mug has a measured diameter of 8 centimeters. The height of the AE Mug has a measurement of approximately 11.4 centimeters, the handle height from the outside of the handle top to bottom to be 9.2 centimeters, the inner handle height from the bottom of the inside to the top to be 7.6 centimeters.
GN Mug
Outer Diameter (cm) 8.5
Inner Diameter (cm) 8
Height (cm) 11.4
Handle Height Outer (cm) 9.2
Handle Height Inner (cm) 7.6
The AE Mug has a white outer and a black interior. On the center of the outside, the GN logo printed on both sides of the handle. The logo is composed of PC components, such as sticks of RAM, capacitors, and fan blades. The design is oriented towards a PC enthusiasts who may be able to recognize the components from videos of component teardowns and analysis.
The AE Mug is listed on the GN store for 15.50 US Dollars. We consider it to be midrange as a quick Amazon browsing has mugs of a similar size from 10-25 US Dollars.
BedHedd Test Mug
We will be using the BedHedd Mug, a mug designed to use as a comparison for all mug tests. The mug will serve as a control as we review more mugs. The BedHedd Mug holds 17 ounces or 500 milliliters. The BedHedd Mug has a measured diameter of 8.2 centimeters. The height of the BedHedd Mug has a measurement of approximately 11.8 centimeters, the handle height from the outside of the handle top to bottom to be 8.8 centimeters, the inner handle height from the bottom of the inside to the top to be 5.6 centimeters.
BedHedd Mug
Outer Diameter (cm) 8.7
Inner Diameter (cm) 8.2
Height (cm) 11.8
Handle Height Outer (cm) 8.8
Handle Height Inner (cm) 5.6
The BedHedd Mug Testing Methodology
We have three usability tests. For this review, we will quickly recap our testing methodology. If you wish to know more about our testing methodology, you can check out our original testing methodology publication.
For the insulation test, we will pour half a liter of boiling water into each mug and rate how well the mug insulates the water from a scale of one to ten, one being unbearably hot and ten being unable to feel any temperature. If the mug is small, we will use the volume of the smaller mug.
In the wash test, we will use our hands to wash the inside of the mug. We will rate the washing experience on a scale of one to ten, one being unwashable and ten being extremely easy to wash.
In the handle test, we will use our hands again to hold the handle. We will rate the holding experience on a scale of one to ten, one being unholdable and four being holdeable with all five fingers.
Insulation Test
The BedHedd Mug scored a value of 2.1, our mug holders rated it lowly due to thin internal walls of the mug.
The AE Mug scored a value of 2.1,our mug holders rated it lowly due to thin internal walls of the mug.
Wash Test
The BedHedd Mug scored a value of 7.4, our mug washers rated it highly due to the wide internal diameter.
The AE Mug scored a value of 7.3, our mug washers rated it lower compared to the BedHedd Mug due to the narrower internal diameter.
Handle Test
The BedHedd Mug scored a value of 3, our mug handlers rated it lowly due to the narrower handle.
The AE Mug scored a value of 4, our mug handlers rated it highly due to the wider handle.
Conclusion
Despite losing to the BedHedd Mug in the wash test, the AE Mug scored higher in the handle test and matched in the insulation test. After the cost of shipping, the AE Mug came out to be 29.49 US Dollars. At this price point, it would be a tough sell for the regular Amazon customer as sets of 4 mugs can be bought for a similar price after shipping. However, we would recommend the AE Mug to users who wish to support GN, take advantage of the wider handle, and appreciate the detailed design.
We bought this mug for this review, if you wish to see more reviews like this, feel free to like the forum post to motivate BedHedd to buy such products.
Disclaimer
If you haven’t already noticed, this is a parody of a GN review, this by far is not a comprehensive review.
5/7 would benchmark again.
While we are typically not talking about rumors, multiple of our sources in the industry told us about their plans to compete in this market. We will keep an eye on this so consider subscribing for more mug reviews in the near future.
Also we are working on a methodology to generate multiple millions of bar-graphs … using blender.
Anyway, that’s all for this one. Thanks for reading, subscribe for more. Go to store.level1techs.com to support us directly or Level1 Techs | Creating videos about technology, science & design | Patreon for some extra videos.
I’ll see you all next time.
Very nicely writen review!
One nitpick:
Assuming the mugs internal volume is a perfect cylinder, the following formula can be used to approximate the volume of said cylinder:
So: \pi*(8/2)²*11\approx502
As for the unit, 1ml = 1cm * 1cm resulting in a mug-capacity of 502ml which is 13% more than the advertised capacity. I would ask for clarification on this urgent matter
I also suck at math :smiley:
Would you recommend this for english breakfast tea?
I haven’t gotten to try tea in it just yet, but because it has a black interior (speaking from experience of my past mugs) it doesn’t show the stains as bad as a white interior.
Also the wider handle makes it nicer when drinking hot liquids, on the other mug, the handle is narrower, which can cause contact between the side of the mug and with my ring and pinky finger
Hi, please find enclosed below One Simple Trick to prevent stains in a white mug.
Feel free to share this with your followers on Social Media and support is on lateprion
Summary
Wash after use
Sorry, it is only for Earl Grey… hot.
