Does anyone know which are correct? Or if Wendell uses something else?
Maybe we can even build a comprehensive guide of all tweaks to hide the KVM
so we can use a VM instead of dualboot without the fear of randomly loosing hundreds of dollars
worth of accounts due to random gamedevs mind changes?
with kind regards
//EDIT: sorry i cant include links … so they are botched
even you try to fully hide the hypervisor the dev can still detect you run in vm its a mater of time before they found out ! the only solution is like finding the ultimate type zero hypervisor that can share hardware directly between os without any type of virtualisation lets say like sriov but full hardware sharing like a bios level hypervisor that you can configure HVM(hardware VM) pining cpu core passthrough portion of gpu and pcie storage controller directly to OS even the io and chipset all that before booting to system … seem like alien dream to go live in another planet
install/enable hyperv in the guest, mainly, and pass through the real cpu and hide other aspects of virtualization. There can be more tricky stuff you can do. But it’s a bit of an arms race, sadly. Lot of misinformed companies out there combating virtualization when in reality it does little to stop cheaters.
if that is activated vm detection is somewhat broken because they cant differentiate the security feature from virtualization.
so nested virtualization + hyperv stuff and nearly all anti cheat is working.
to be warned: some consider that “anti cheat circumvention” and therefore a bannable offense so it wont just kick you … (escape from tarkov desteny 2 etc … all the ***** devs )
tbh i just stopped playing most games tho … nearly all the devs only make games for money now days. Not games which also earn money.
(Path of exile currently is the last game which i find worthy to put a few hours in to ^^)
is there a reason to go for a “custom” id over the one from a bare metal windows install?
I always looked at what the vendor id is in windows and than put it into the vm config
