So Starbound has become an almost overnight success, and because of this, everyone has to figure out how this changing beta game's mechanics function. I hope this forum topic will be a growing accumulation of hints, tips and tricks to making it through the game.
Tip:
You can press shift to make your various tools function for a single block instead of a square of four blocks, this is very useful when building a mass of blocks around an enemy. You can poke a small enough hole and fire arrows at them from angles that they are unable to return fire from. This is necessary with the most recent updates, as the ability to attack through blocks has been removed.
You can warp to your friends ships in multiplayer. Doing so can save you time and frustration when you want to be able to move back and forth from distant galaxies. Thus far I've only been able to confirm that it works for the transition from Alpha to Beta districts. If anyone can verify longer distances of warp travel, that would be awesome.
It is possible to remove water, poisonous fluid and lava by covering them with blocks, you can even dig through the blocks that you placed. This is an interesting way to travel through the mantle of the planet. All large planets that I've come across have a massive layer of lava that you reach after tunneling straight down. You can continue traveling straight down by replacing the lava with other materials and digging them back up, leaving a shell around yourself. You can even find ore floating about the lava that is captured in the newly laid material.
Typically things that seem warm actually are: camp fires are great, but not typically very useful to carry about all over the place when there are better options. Take an oven with you for quicker heating, or a smithing forge to smelt ore on-the-go. Many tools produce actual heat and will keep you from freezing when the going gets cold.
You must have an open area to warp to your ship. Ironically, if you are close to the surface, using the pick and right clicking will take out the background material. Doing so near the surface will greet you with a view of the sky, and you can warp to your ship.
You can store more things on your ship: place chests and use them. Given that a great many things don't work quite the same on your ship, it is great to see that storage isn't one of them. In certain areas you can come across laboratories from the monkey-people. These occasionally have stackable storage boxes in them. These are very useful.
Dig up lots of coal: Coal is not only important as it is the only source of fuel for your ship (as of the latest update) but it is also vital for torches and steel. It may also be important for even more materials, but I've not made it far enough to find them.
Falling from great heights is a very bad idea. Falling from great heights into water? Totally okay. Just make sure that the water you intend to fall into is actually deeper than you are tall, otherwise you'll incur some damage, although the water does slightly reduce fall damage anyway. Hint: the update lowers the distance for fall damage, so be even more careful of high places.
Although you can see the terminal and make commands from a friend's ship, refrain from doing so, as it does not move the ship you are on, but instead moves your own ship. This is a clever way of reappropriating their fuel, however.
picking items that contain other items will result in the dropping of all items held within as it becomes a retrievable item. So if you pick a crate, it becomes selectable for inventory as does all of its former contents. This is faster for pickup if you have plenty of space for useless junk.
It is a good idea to pick a home planet to return to, especially in multi-player where you can leave a ship behind to act as a portal. Here you can deposit all of the items that you don't use, like ingots of materials. Although those blocks of gold and silver may look nice, they are far more functional next to the metalworking tools.
Right clicking on a set of items such as blocks or ore will pick up half of the amount within the set.
Right clicking within the travel map zooms out to show the planets around your current host star. right clicking again will take you to the full star map for the area. Expect to do a lot of zooming in and out.
The newest game mechanic has changed the danger level of all planets within the zones to correspond in number to how far along you've made it in the greek alphabet. Alpha=1, beta=2, etc. This does not necessarily make them all equally difficult as some have more prevalent sub-boss-like characters to do battle with. Some instead just opt to be incredible unfair and have oodles of health or defense.
You can switch through your usable items with the number pad, or anything mapped to it, if you happen to have a mouse with tons of buttons.
pressing e while hovering the cursor over obvious background elements sometimes allows for you to interact with them. For example, tomato plants will yield a tomato, plant fiber and seeds. Tulips will provide petals that you can use for dye.
okay, so it has been a while. And I have good and bad news for you Starbounders.
if you've not been playing since Angry Koala came out, you're gonna have a hard time. Ships and worlds have been reset, but your character still has all of the things previously outfitted with. So you can rape those tier one planets for stuff. I was drilling to the center of my home planet with a diamond drill to go swimming in lava with my impervium armor. It was a fun day.
Low gravity has been introduced. Be aware that gravity fields are now a thing. Some areas, usually pre-fab dungeons have low gravity.
More sub-bosses. These dudes are seriously annoying.
You can no longer land on moon biomes without the appropriate gear. That you make with durasteel. The game got more annoying with that one. There are moon biomes and asteroid fields in the first sector that you cannot use because it requires a material you can only craft after reaching the delta sector.
Wiring tools let you control objects, such as doors, with other objects.
Some weather can now hurt you. Watch out for acid rain.
Bosses will still despawn if you drag them too far from the warp point and then die. Be aware that some bosses will glitch through blocks if you capture them in too small of a container. The jellyfish did that. Not very funny if it's already angry at you.
Other things about the fourth boss, it isn't aggro until you attack it. Take some time to box it in carefully before beginning the onslaught.
When in your inventory you can restore your digging implement by selecting the appropriate metal ore or a whole diamond and then right clicking your digging implement. Works on picks and drills.
some background items may be attacked with weapons to produce plant fibers
Slime Biomes, much like desert biomes, are awesome.
Butterfly boost is by far the best tech. You can literally fly indefinitely by pulsing it. (hint, with a breather apparatus and cold weather garments you can fly straight up and get to some asteroids.)
WOW thanks for all the nice hints so far :D If anyone is interested I could add Step by step tutorial how to add your own music for all the instruments.But basically you just change your midi files to ABC files whit conventer.
Thanks. This game has some peculiarities and the instructions are not necessarily clear. So I just started posting what I found while playing, in case someone came along to see them. I don't really bother with the instruments because, well, there are apexes to kill and planets to hollow out. I will also eventually find out if it is possible to completely surround the very bottom of the screen in bricks. I will build a base at the core of my home planet and punch a hole straight down so I warp there. Then I'll just butterfly boost my way to the surface to explore or whatever.
When I first did buy the game I did play it all most 50 hours straight 3-6 days, and when I did beat all the bosses and got the best armor . . .the playing short of got boring . . But if you are planning to play, I would not mind joining, and maybe making new character would be a good idea. But I am eager to know, do you have any idea when they are going to release next version for the game ?
