Well whatever's do you guys think of this, if you correct me please just correct the ram, case, power supply, motherboard and hdd because I built this in mind with having a new 8 core cpu and two graphics cards for 1200 or less.
But the over all build is really good right, I mean I see people building 1500 dollar builds for gaming and getting lower pwer gpus than this and only getting one.
It might work great but from my exp. with mid towers. Its gonna be warm. A full tower with good airflow would be in order. At least for the gpu side of things.
well the point is what you need to learn is putting tons of gpu power in a system does not make a system as a good system. a system needs to be good balanced.
For example a 970 chipset board with only one pci-e 2.0 slot at 16X and a second one at 4X is not realy made for dual gpu setup´s.
Also the power delivery of a mobo is realy important. a motherboard is the base of the system. everything needs to be balanced. powerhungry 8 core cpu on a cheap 970 board is asking for troubles. because those board contain such a cheap power delivery parts thats the reason why they cheap.. just not designed for 8 cores.
Same counts ofr intel side by the way. but for amd in general FX8320 8350 needs a decent 990FX chipset board. especialy wenn you wanne overclock, and sli/cf capability´s
I think I some where said that you can find a better motherboard, I actually did this in a hurry as you can see because If I didn't it wouldn't have that Hitachi hdd.
Don't get that Hard Drive, SV35 is a surveillance series drive: http://www.seagate.com/au/en/internal-hard-drives/consumer-electronics/sv35/
It is made for being written to constantly. The guys above are right, for that price get a 1Tb Caviar blue, or a Seagate Barracuda.
Apart from that and the motherboard (seriously 2 x 280X's with 1 x16 PCIe 2 slot and a x4 slot.... not even worth it) - the ram, GPU, case, PSU and CPU are good though :)
You might even want to spend the $30 ish more for the 8350, I have heard that is way better than the 8320 especially for the price difference.
